Need to replace ATI Procharger Anti-surge (bypass valve) what to get???
Well, to complete my ATI install, I'm going to need a anti-surge (bypass valve).
What should I get? The ATI one that normally comes witht the kit? I think it's called a Pro-flo. This is for a P1SC in my C5 running 6-7psi and it vents to the atmosphere.
What do you guys recommend???
Thanks
Steve
Thanks
Steve
I would recommend the Mondo bypass valve. That is what I will be running here shortly. Others have used it with no problems. If you want you could also buy the ATI race ready bypass valve but that is a little more expensive.
Are you after looks or just concerned with functionality? The ProFlo valve is suitable up to an F1's airflow. If you get to a point where you exceed that then you need a valve capable of dumping more volume.
I went with ATI's racing version. Judging by the sound the car makes when I lift, it works much better than the one that comes with their kit. And I dump it back into the inlet. I may change that later if / when I get EPP's metal inlet hat.
Steve get a Hyperboost or the Turbo XS H25, there both alot better than the Bosch and there nice and compact to fit almost anywhere. Talk to Brian at ICS on the C5 forum and he can set you up with the Hyperboost. Also Brian what injecters are you going to run? I'll get that file over to you soon-just can't find my USB card?
Originally Posted by Steve01SS
Looks dont concern me. I just need one that will work with my setup.
Keep in mind that the sole purpose of the part is to dump airflow when you close the throttle. That's it. Its not to regulate boost or anything like that. Its there to protect the system from a large pressure spike that would occur from removing the airflow demand and displacement of the engine.
Still looking at options.. the Vortech bypass looks nice.... hmm.... I heard the ATI bypass sucks. Need a couple lil things left, then doing the install shortly.
Steve
If they run out of fuel with this setup, then I'm going with 60lb Motrons.
hey man... just emailed you as well.. yeah I currently have FMS SVO 42's (green tops) that are at 65% duty cycle with the current N/A setup. BUT.. the car is making a ***** 50psi of fuel pressure and then 48psi at WOT. So, I'm doing a Racetronix pump kit and running either a 6 or 8 AN feed line from tank to the rail with an aeromotive regulator mounted at the rail and a set of billet rails to go with it. I haven't decided yet whether I'm going to use the stock feed line as a return (with the OEM filter/regulator) bypassed or just run a 6AN return as well. Bypassing all stock lines. Doing it myself and can be done for a real decent cost.
Steve
Steve
