AFR 205's With T2 cam???
will this be a good setup? It will work right? A friends has a T2 cam and is looking at AFR 205's. He found a good deal on them . He just wants some good info thanx
Don't mill the heads too much or you may have some PTV issues. I agree with BSHELL, if you find a good deal on AFR's get'em. That combo should make some pretty good power. I am running a smaller cam (228/232 588/592) making 440/420 to the wheels in my Z06.
Definitly mill the heads, you can knock them down .020" safely with the torquer 2...that will give you a nice bump in compression. I have a set of AFR 205's with upgraded 2.04" intake valves for $2000 plus shipping, I can also deck them for 50 dollars down to a 64cc chamber which would give you about 10.6:1
Zach
Zach
