Fuel pressure regulator plumbing?
I just got an Aeromotive FPR and fuel rails. I will be running -8AN feed and -6AN return lines. My question is what is the best way to plumb the fuel rails and FPR?
I have seen it done a couple ways.
1) Feed line to FPR then out of FPR to fuel rail and capped at the end of the second fuel rail.
2) Feed line directly to Fuel rail, through second rail and then into the FPR.
Which one of these is better? Is there another option I am missing?
I would think having the FPR after the rail would keep the pressure more stable.
Here is my ghetto diagram:
#2 is a better setup and is how mine is run except I've got -8 going both ways. It'll provide more stable fuel pressure especially if you plan to make a lot of power. BTW, if you want a nice place to mount yoru fuel pressure gauge aeroquip makes a nice 3/8" NPT to -8 fitting that has a 1/8" NPT port coming off the side so you can mount your gauge on the front of one of your fuel rails.
Don't forget the recommended way (from Aeromotive, anyway): pump is supplied via Y to both fuel rails, then both to the regulator, then return to the tank.
There have been several reports of this causing a slow rise in tank fuel temperature (due to engine heat being transported back to the tank via the fuel); eventually causing vapor lock. But this method is the best way to assure stable fuel pressure at the injectors.
jp
jp
jp
jp
what exactly vapor locks? i've had extremely high fuel temp but not sure of vapor lock?
I am not familiar with the Aeromotive FPR, but be careful. The option 2 requires a "return" regulator, which is very different from either a bypass regulator (option 1), or a traditional in-line supply type regulator. I'm sure if you follow the manufacturers recommendations, you will be fine.
Andy1
Andy1
Aeromotive regs can be run both ways, the suggest option 2 is best but you can run them like option 1, mine is an aeromotive 13109 reg and I run it like picture 1, with constant 58psi supply.
Vaporlock?
Gasoline turns to vapor at around 130 degrees F. If your fuel gets that hot, it may disrupt the pump's action since it is designed to pump liquid, not vapor.
jp
jp
Jim
aeromotive 13109 fpr question
I had a friend tell me that this regulator has to have vacuum reference hooked up to be adjusted and work correctly.......aeromotive told me, if my setup originally had vacuum reference to hook it up, but if it didn't.....don't hook it up. My setup is 6.0L/L92 head/02' camaro computer, L76 car intake with single fuel rail inlet. I was gonna hookup like pic #1......do I, or do I not, need to use vacuum reference on the aeromotive 13109 fpr?
Increasing the pressure at the rail increases the effective lb rating of the injectors. For example SVO 30 lb injectors are rated at 30 lbs for ford vehicles but act more like 36 lb injectors at the gm fuel pressure. Of course there is a limit to how much you can crank up the pressure.
part number
Does anyone have a part number for this? I want to mount mine on the fuel rail on the vette.
