YS + YSi Lets hear what they can do!!
https://netfiles.uiuc.edu/nbrinkw2/B...boosted_06.htm
All the info you need. Almost all of our cars are on it!
Originally Posted by Old Car Guy
Even T-Trims... What do you have!
Is 800rwhp capable with a YSi and meth? What cubes is best, 364, 402,427, 441?
Oh yea You can do 800 on a YSI easy with the cubes. My 650 is on a little 347
Forged 382, V7 YSi, 8.7:1 CR, 224/230 on 115 LSA cam, Edelbrock 215cc heads with a T56
A reasonably mild build IMO. Idles good, drives brilliantly.
I made 735rwhp and 666rwtq on pump fuel only. Day before that I ran 11.05 @ 138mph but that was with a leaking BOV. Only discovered that at the dyno.
We only revved it to 6000rpm on the Dyno, as power appeared to be peaking there which was a little odd. I was only there out of curiosity anyway, wasnt fussed about revving the nuts off it.
Had to back off the timing though to get a smooth run. The Dynapack was having strange problems if I increased the timing. So no doubt it would have made more power.
A few weeks later, with some meth injection and at a different track, I ran 10.54 @ 145mph. No other changes to the car aside from meth +tuning.
Being manual, and with crappy tyres, 60fts are still poor.
Hopefully I'll get out again next weekend ( 14/15 ) if the weather stays dry.
I now have some MT DR's, and will be running with a Victor Jnr intake manifold setup..
I had hoped to have a taller diff as 145mph is me at 7000rpm with the old Nittos, but relying on suppliers from the US to get things to me in a reasonable time, seems to be an extremely hard thing to do.
Ive only just received the bits I need to get my Victor jnr up and running !!!
Some very low 10's and higher than 145 would be nice.
LOL comes down to dollars? big cubes=big money. if it were cheaper we'd all have 427's lol.
8 and 10 ribs are what I've personally seen used. haven't seen a cogged on a vortech setup yet.
Hopefully I'll be running in a couple of weeks. Here's a couple that put down 800+ rwhp.https://ls1tech.com/forums/showthrea...&highlight=ysi
The Aussies use a cog drive on their engines. I was going to, but I ended up getting pullies made for a custom 12-rib.
Bigger engines would be good....but smaller has some things going for it. Less torque low down for starters. If shooting for big hp, this can be a good thing, as its makes traction easier.
Bigger cubes mean more they are thirstier. I dont care how cheap your fuel is in the US, but for me, that was a big consideration.
And if you can make the similar power with a smaller engine, for less money, that will use less fuel....
Makes sense just to do it.
