Max power out of T76??
people with these setups, can you let me know what power your making?
my setup will consist of 6.0L block, ported 317 heads, (either truck manifolds or OhioFI manifolds)
i'm looking to make 750-800 on pump gas.
A guy i'm working with thinks that w/ the displacement (364ci) that i'll max it out on higher boost. He advised to look into possibly a T-88.
Any suggestions?
this will be a street/track car.
Any suggestions?
Mine is a 76 but its a GTS. So it is a little different then what u got.
That is at 12 psi on the stock short block. That aint the 661 rwhp one as i dunno where the hell that is. GL man
John
John
Originally Posted by parish8
best i could do on with a camed 6.0 and t76 was 640rwhp. thats thru a 4l80 and a tcase and i was running good gas. i saw good gains to about 14psi and then just hot air with more boost after that.
Mike
single digit dreamer
Originally Posted by engineermike
That's odd. With the T76GTS and 388 cid, I see huge gains when I go from 14 psi up to 20 psi. Been way over 640 rwhp also.
Mike
Mike
