(Two Newb Qs) Rebuild engine on the side: LQ4/9 or LS1?
I'd like to pick up a super-cheap used shortblock to freshen on the side instead of pulling my LS1 with 106,xxx. That way, I can continue to drive my only car daily, and also gain a little experience in the process.
Now, just to show how much a newb I am, if I were to rebuild a high-miles shortblock that's been really been beat on, I would want to replace the:
1. Main Bearings
2. Connecting Rod Bearings
3. Cam Bearings
4: Piston Rings
QUESTION #1: Is that all that needs to be replaced in a rebuild? Either way, I'd appreciate a link to a good rebuild kits and some tips on what to look for. Remember, I'm trying to do this a cheap as possible.
QUESTION #2: Would I be better off going with an LQ4, LQ9, or LS1 to rebuild? The LQ's are heavier, aren't the original engine type, but have a larger bore. I'll be spraying the engine, but only a 150 shot so the added strength of the LQ -- if there truly is any -- is completely unimportant to me.
Thanks!
1. Main Bearings
3. Cam Bearings
4: Piston Rings
Thanks!
oil pump and timing chain is part of the lower end {shortblock} of a engine
For what you want you should freshen up what you currently have . The money saved could get you a set of forged lightweight pistons and put in some katech rod bolts.
Originally Posted by Randy WS6
You can reuse all bolt except the stock head bolts they are torque to yield .
Well as far as your parts list goes it all depends on how far you wanna o w/ your build. But you can search on www.ls1techhowto.com and get some more ideas
