changing plugs with long tubes?????
Old 10-18-2006, 10:00 PM
bowtierodder's Avatar
Default changing plugs with long tubes?????
how hard is it??..... i have pacesetter's
Old 10-19-2006, 02:22 AM
CASHss99's Avatar
EASY... just sqeeze your hand in there.. it takes me 30min to do it on ls1 remove the passenger side coil pack rack
Old 10-20-2006, 01:49 AM
zach_ws6's Avatar
it is alright. it isnt fun. you will need to get underneath the car to get to the very back ones. i have done it a couple times already. just be patient. it will be easier if you dont have the emissions headers, cause they have those damn extensions that get right in the way.
Old 10-20-2006, 02:32 AM
RoadHazard's Avatar
It would help a lot if you removed the passenger side coil pack when you installed the headers and left out the last bolt when reinstalled. You should be able to get #8 from top if you remove the coil pack.
Old 10-20-2006, 03:44 AM
CASHss99's Avatar
i get em all up top man just be smart eeeeasy
Old 10-20-2006, 08:22 AM
chris2000ss's Avatar
+1 for removing the passenger side coil pack.
Old 10-20-2006, 09:01 AM
bjamick's Avatar
bout a 30 min job. its not all that bad. just tight squeeze to get your hand alond with ratchet in there.
Old 10-21-2006, 06:30 AM
Moderator
davered00ss's Avatar
A lot easier with headers than stock manifolds. You should have all the emissions crap gone.
Old 10-21-2006, 01:39 PM
~RedLineLs1~'s Avatar
Its really not too difficult. The 1st time will be somewhat challenging but it gets a lot easier. I dont even bother removing the coil packs anymore. Once you get half-way decent at changing them, it doesn't take longer than 45 minutes or so.
