Oil pressure port?
Oil pressure port?
is there a second port to obtain oil pressure. my ford sending unit works backwards of the GM sender and there is no room to split the factory hole.
next to the oil filter there is a block with a hole in it bolted to the block. i dont think its the oil bypass. can i drill and tap that to use. Thanks, rich.
