AFR 205's/w G5 X3 cam?? Did you mill..?
Old 10-24-2006, 07:30 AM
YO-EL's Avatar
Default AFR 205's/w G5 X3 cam?? Did you mill..?
Is it necessary to mill the 205's or can they be used straight out of the box?
Old 10-24-2006, 07:39 AM
PREDATOR-Z's Avatar
If you mill you have to flycut
Old 10-24-2006, 08:40 AM
N4cer's Avatar
If you spend that kind of money and don't mill, you're crazy. Don't waste your money.
I was afraid to flycut until I blueprinted my motor in my new setup and realized that cutting .070" out of the piston is nothing. So we cut. Easy enough. What do you think the flycutting will do to the motor? Or is it the additional cost that scares you? It was the cost that worried me. Until I realized I could buy the tool for $140 and use an old head and then I can even let people rent it for a fee.
Old 10-24-2006, 12:20 PM
JG853's Avatar
What are the benefits of flycutting? (Other than making room for the Cam). What are the disadvantages of flycutting - Does it hurt compression or anything?
JG853
Old 10-24-2006, 12:37 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
JG853
No benefits beside making room for the larger cam (which can then provide it's own benefits with the right set-up).
It will displace some volume (the only negative besides potential cost and time if notching yourself) which has to be compensated in the milling of the heads (1-2 cc's only). Thats why LG consistantly gets away with a 59 cc head on pump gas....it essentially creates the same CR as a 61 cc head without valve reliefs which puts you in the 11.4 CR range....good for a larger cam with more overlap and totally fine with 92 or better octane in that situation.
Tony
Old 10-24-2006, 07:40 PM
allngn_c5's Avatar
Tony as usual is right on the money !!
Old 10-24-2006, 09:16 PM
waterbug1999's Avatar
I notched my pistons in the garage, not hard at all.. I just rented everything from LGM and got er done!
Old 10-24-2006, 09:26 PM
Super Hulk Smash
JakeFusion's Avatar
LG confirmed that with the 114 you don't have (.080" intake clearance) to and the 112 you'd have to check (.060" clearance)... and that's a 59cc head milled .042" with .040" Cometics. Not real sure how that's happening, but eh.
I'd mill down 205s to at least 62cc and probably go all the way down to 59cc with a G5X3 and flycut for safety.
Old 10-25-2006, 12:47 AM
PREDATOR-Z's Avatar
I will cut my left nut (I'll keep one for fun ) if the G5X3 fits with 59cc mill and .040 Cometics.
Search for their initial setup, flycut all the way.
That cam is a 234/242 and has the clearances you mention on stock heads.
That is why the 112 will "FIT" but is below .080/.100 recommended street PTV tolerances. (some run tighter but some poeple base jump too )
Old 10-25-2006, 04:42 AM
Thimble's Avatar
I think there is a lot of confusion out there lately because of these comments from Louis@LG:
Originally Posted by Louis
AFRs milled to 59cc with a 40 thou gasket require no flycutting. Any other milled head I cannot speak for, but there is more PTV with that AFR setup than a cam only, stock head setup.
Louis
Hi guys, there is 220 thou of valve drop with a milled, 59cc AFR and .040 cometics.
There is 200 thou of valve drop on a stock motor.
Any X series( G5, X1, X2, X3, X4, 111/112/114 excluding the xX ( which in most cases, thats install only here at the shop) will fit on a stock engine, 112 or 114. The X3 110 will not clear stock heads, but it will be close on the AFRs. You gain quite a bit of PTV with AFRs. If you are not sure, and want to know what your setup came in at, check it.
These quotes and much more discussion is in this thread:
https://ls1tech.com/forums/generation-iii-internal-engine/569395-g5x3-vs-ms3.html
Still doesn't make sense to me either.
Old 10-25-2006, 10:18 AM
Super Hulk Smash
JakeFusion's Avatar
I wonder if LG is also doing something with the valves that gives more PtV clearance? They call them the LG/AFR heads, but I thought it was just a mill down to 59cc and the installation of Comp 921 springs.
