A little help
Old 10-24-2006, 08:54 PM
02' hawk's Avatar
Default A little help
I just got a catch can and a check valve that i need to install it this weekend. My problem is i know how to install the catch can, but where do i put the one-way check valve in the PCV line? I am having a problem with pressureizing the crank case. It has blown the dip stick out too many times and it's about time i fix it.
Old 10-25-2006, 02:56 AM
ATL HAWK's Avatar
Sorry to get off the subject, but go to a GMC,CHEVY,PONTIAC,CADILLAC dealer and try this PCV VALVE and see if this helps your oil consumption. I saw this at ws6store.com and I have a 01 firehawk and I have only driven 500 miles with this pcv valve, so I can not say at this moment that it has helped.................but this maybe the best fix us LS1 engines have. I went to Buster Miles Chevrolet in Helena Alabama and purchased for $6.75.
98-02 LS1 GM PCV Valve (New Design)
[12572717] $6.99
Click to enlarge
As many of you know, the PCV system on the 98-02 LS1's isnt exactly the greatest system on the planet.....burning up to 1 quart every 3K miles. After many complaints, GM finally issed a service bulletin to address this issue on all of the GEN 3 engines. They have replaced the ball-type PCV valve with a new fixed orifice design that is used in the GM trucks. This design will help reduce oil-consumption on your LS1.
New GM part. Please allow 1-2 days to ship out.
Old 10-25-2006, 12:35 PM
02' hawk's Avatar
I already have one that looks like it but it has two fittings on it. one at each end that plugs directly into the hoses. Where do i put this? This is a procharged engine.
Old 10-25-2006, 12:55 PM
JMBLOWNWS6's Avatar
Put it on the line that connects to the intake.
Old 10-25-2006, 04:43 PM
02' hawk's Avatar
Which way should the valve be set-up?
Old 10-25-2006, 05:30 PM
JMBLOWNWS6's Avatar
Boost comes this way <---------------- Put the check valve flow this way ------> Thats way when the boost comes <------------ the check valve closes
Old 10-25-2006, 11:26 PM
02' hawk's Avatar
Still a little confused.
Old 10-26-2006, 01:50 PM
02' hawk's Avatar
Anyone have any pics of where to install this creature?
