Advanced Engineering Tech For the more hardcore LS1TECH residents
Max DCR for 91 octane?
Old 10-25-2006, 02:22 PM
Gannet's Avatar
Default Max DCR for 91 octane?
I did some searches on this but got no hits.
Any comments on what a good maximum DCR would be for 91 octane? I usually run 93, but there are places we hit when on vacation that only have 91 available.
Old 10-25-2006, 03:31 PM
novass72's Avatar
i would say 11.5 would be the highest, but I'm sure that some people have gone higher. Just my thoughts.
Old 10-25-2006, 03:56 PM
Gannet's Avatar
While digging through the results from another search that did bring up some hits, someone mentioned that 8.5 was considered about the DCR limit for 91 octane, and 8.8 for 93.
Anyone have comments or experiences about that? I'd be interested in hearing from those of you who live in hot places with 91 gas being all that's available.
Old 10-25-2006, 04:02 PM
novass72's Avatar
sorry I didn't notice the DCR!
Old 10-25-2006, 07:05 PM
slow trap's Avatar
you can run it around 8.8 on 93 and throw in some octane booster when you can only find 91. that way wou have alittle more power all the time and still be safe,ehhhh,safer i mean.
Old 10-27-2006, 03:50 PM
GFORCE1320's Avatar
I run 8.6 on 91 octane and it's on the ragged edge. My engine likes 22-23 degrees of timing, It gets a little kr here and there but when I run on race gas, I don't get any kr but I don't get any gains gains in et either, so that tells me that I setting right where I want to be.
Old 10-27-2006, 04:09 PM
Gannet's Avatar
Good info, thanks very much. That seems to confirm the other stuff I've read.
I think I'm going to target 8.4-8.5.
Old 10-27-2006, 04:12 PM
GFORCE1320's Avatar
You need to keep the quench area to around .32-.030 that will help also.
Old 10-27-2006, 04:13 PM
GFORCE1320's Avatar
BTW, my static compression is 11.96-1
Old 10-27-2006, 04:19 PM
gun5l1ng3r's Avatar
Almost 12:1 and on 91!!!
Wow I envy you!
Old 10-27-2006, 04:22 PM
GFORCE1320's Avatar
I really did my home work...and then did it again...
Old 10-27-2006, 04:54 PM
Gannet's Avatar
That's just the difference between the deck height and the gasket thickness, right?
So on an LS-1 with the deck height at -0.006 (out) you would need a compressed gasket thickness of 0.036 - 0.038, is that right?
Can you get head gaskets in that thickness?
Bear with me guys, I'm trying to learn this stuff.
Old 10-27-2006, 05:08 PM
GFORCE1320's Avatar
Quench is the distance between the top of your piston and the cylinder head (correct me if I'm wrong) at tdc.
I'm running flat top JE's that are 0 deck, they do not stick out.
My quench came out to be .040, I was shooting for .032 but .040 was what I had to live with. Seems to work fine thought.
After saying all that, I woud say .030 to .040 range is a good quench distance.
Old 10-27-2006, 05:12 PM
GFORCE1320's Avatar
Here is what the calculator shows that I use.
Old 10-28-2006, 07:04 AM
chuntington101's Avatar
sorry a bit off topic but what about with a forced induction engine???
thanks Chris
Old 10-28-2006, 08:25 AM
GFORCE1320's Avatar
Not sure on forced induction, I know you want to be around 8 to 8.5 to1 on static compression. Don't know what the dynamic would need to be..
Old 10-29-2006, 09:07 AM
slowride's Avatar
I'd just use a Cometic .040" It would be the close to what you are looking for. My 383 is 11.83ish to 1 and in the low 8.4 DCR range. I run stock gaskets with the pistons .010" out for ~.043-.045 quench and burn 92 octane with no problems. I could step up the quench and gain some compression, but it runs good so I'm fine with my results
Old 10-29-2006, 03:09 PM
AppleMac's Avatar
I am running 12.3 scr and 8.75 dcr on 93
Old 10-29-2006, 03:18 PM
miami993c297's Avatar
Any pinging or KR with those numbers?
what kind of tune?
Old 10-29-2006, 04:15 PM
AppleMac's Avatar
Nope, No knock retard or "pinging."
A good tune lol... MAF Tuned with HPT if that's what you mean...
Quick Reply: Max DCR for 91 octane?
