Advanced Engineering Tech For the more hardcore LS1TECH residents
Trying to make a set of custom MSD wires...
Old 10-28-2006, 01:03 PM
AppleMac's Avatar
Default Trying to make a set of custom MSD wires...
Hi guys,
Not getting much usable help in external engines, So i figured I would ask you smart people
I would like to make a custom set of MSD 8.5mm wires for my coil pack relocation project.
Planing on using this wire: P/N MSD-34019
http://store.summitracing.com/partde...5&autoview=sku
Now I need to get boots and terminals for each end...
This is where I am having trouble... What boots and terminals do I need?
This is going to be used on a LSx engine (LS2 to be exact) with coil packs.
Part numbers or links would be AWESOME!!!
Thanks guys!
Old 10-28-2006, 10:15 PM
Adrenaline_Z's Avatar
Two questions come to mind:
- Why are you relocating the coils?
- Where are you going to relocate them?
Old 10-28-2006, 10:44 PM
AppleMac's Avatar
Question one: Getting new valve covers... New valve covers do not have a provision for coil pack mounts... (This is how I wanted it for a nice clean look)
Question two: My car is a GTO... They are going on the fender area.
Old 10-29-2006, 01:32 AM
under pressure's Avatar
I have made up several sets of MSD wires for LS1 coil relocations. The only luck I have had was to buy a set of unfinished MSD LT1 plug wires and crimp the spark plug end on myself. The Optispark distributor cap has the same connectors that the LS1 coils use. I highly recommend the MSD plug wire crimping pliers/tool - it makes it easy.If anybody else has a source for the LS1 coil connectors please speak up.
Old 10-29-2006, 06:57 AM
Old Geezer's Avatar
Lightbulb Try..
Contacting John Spina, at CASPERS Electronics.
http://www.casperselectronics.com/
He has alot of custom wire stuff, and is very knowledgeble.
Plus that, he's a NICE guy!
Old 10-29-2006, 08:03 AM
AppleMac's Avatar
I have been doing a little more looking....
And I pulled this pic from Chrome and Performance's site:
Then I found these plugs at summit:
They look pretty similar... They say they are already assembled but I wonder how long they are...
Old 10-29-2006, 08:19 AM
427's Avatar
Call MSD. They have a LS custom wire set that comes with exactly what you need. I don't know the part number off the top of my head.
Kurt
Old 10-29-2006, 09:12 AM
AppleMac's Avatar
Thanks 427!
I just found this kit: MSD-32079
Just wonder if they include neough wire for my application.
I will call them Monday and see what they say.
Thanks again
Old 10-29-2006, 08:19 PM
427's Avatar
The wires are pretty long and have a 90 degree boot on one end and a straight on the other. You just cut to length and add the coil ends.
Kurt
Old 10-29-2006, 09:15 PM
AppleMac's Avatar
Thanks Kurt!
I really appreciate the help.
You will be getting a call from me as soon as I can afford to buy one of your 402's
Quick Reply: Trying to make a set of custom MSD wires...
