Drag Racing Tech
What is the best/lighest battery?
Old 10-30-2006, 10:16 PM
blackls6's Avatar
Default What is the best/lighest battery?
Yeah I have a 03 z06 and would like to get the lighest battery possible. I hear oddesy is good but which one should I go with?
Old 10-30-2006, 10:57 PM
Magnet's Avatar
from what i hear oddyssey pc680 LINK
Old 10-31-2006, 11:01 PM
blackls6's Avatar
Is that a street battery?
Old 10-31-2006, 11:34 PM
prostock_bigblock's Avatar
yupp.
Old 11-01-2006, 03:22 PM
Nate_Taufer's Avatar
Search is your friend. There is a new thread for this battery every week.
Nate
Old 11-01-2006, 03:24 PM
T6Rocket's Avatar
I would just use it for track trips. Using it every day in a car will wear it down.
Mine is working well, BTW!
Al
Old 11-01-2006, 07:49 PM
2001WS6Vert's Avatar
I'd recommend the pc925. It has the power to perform the same or better than stock and still saves a good deal of weight. It weighs 25lbs. vs 13 for the pc680. I previously had the pc680 but had slow cranking and couldn't run accessories for any time at all.
Old 11-01-2006, 11:08 PM
blackls6's Avatar
I do not drive my car everday. I normally only drive it 1-2 time a week. Would this battery be enough for that? And that is the lightest battery out there correct? Also, it will be going in a c5 vette, will I have to modify any of the terminals or anything else to make it fit?
Old 11-03-2006, 02:32 PM
T6Rocket's Avatar
The alarm would drain it sitting in the car all week. That is the lightest battery you can get and it is for track use only. It is a top post.
I have two batteries - one a regular strong, heavy one with 850 CCA, and the PC680 that gets used 5 times a year!
Al
