View Poll Results: Mileage the 4L60-E lasted
25,000 miles
6
7.89%
50,000 miles
16
21.05%
100,000 miles
15
19.74%
125,000 miles
4
5.26%
150,000 miles
2
2.63%
175,000 miles
1
1.32%
Still going strong
31
40.79%
Blew up and swapped for a T-56
1
1.32%
Voters: 76. You may not vote on this poll
How long did it last poll
Old 10-31-2006, 11:42 AM
98-LS1's Avatar
Default How long did it last poll
I'm just curious as to how many miles ya'll have put on the old Automatic before it died. So far I'm at 132,000 and I'm trying to blow it up but haven't had any luck, these transmission's seem to be pretty darn stout. List mileage when it went out and what exactly happened to it. This could be educational....
Old 10-31-2006, 12:28 PM
12Gauge's Avatar
Mine held up to about 200,000 before 3rd and 4th were gone. That was about 6000 miles after dropping in the 383.
Old 10-31-2006, 12:31 PM
98-LS1's Avatar
That's not too bad, I was curious because I'm installing my cam in two weeks since I'll have four days off from work and everyone has been telling me my transmission will fly apart. I hope it does so I can go ahead and get my T-56 installed.
Old 10-31-2006, 12:40 PM
HossZ28's Avatar
I voted still going strong but I have 56k miles.
Old 10-31-2006, 12:57 PM
jpat1023's Avatar
Mine lost the 3-4 clutch packs at around 70,000, the car was stock until 60,000, and bolt-ons when it blew up...I feel like I was a little unlucky...
Old 10-31-2006, 03:34 PM
squints88's Avatar
luckier than me...
I just bought camaro a month ago (mods in sig) and i lost 3 and 4 just this weekend. 62k on the clock. this sucks.
Old 10-31-2006, 03:51 PM
john563's Avatar
mine whent at 71000 about amonth after my cam install,but have a friend with 400rwhp cam only a4 and its doing fine but he only has 20000 miles on it
Old 10-31-2006, 04:39 PM
ls1_doc's Avatar
Yeah mine went at 55,000 with bolt ons. I lost 3 and 4 as well.
Old 10-31-2006, 10:09 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Mine died days after I upped the boost to 11 psi (518 rwhp).
Old 10-31-2006, 11:35 PM
revtime's Avatar
My stock one lasted about 130k, not bad mostly stock motor, and lost 2nd gear. I had one built by a local guy and it lasted 26k before losing 3 and 4.
Put a TH400 in and fixed the problem.
Old 11-01-2006, 05:14 PM
SierraSport's Avatar
I had problem with the first tranny(sensor)@ 8,000/I blew it up @ 36,000 .. I just blew the Second @ 80,000 and im in a truck ..
Old 11-02-2006, 07:21 PM
SSPEEDY's Avatar
55K miles.
Bolt ons early on, stall at 30k, cam went in at 40k. Good amount of track passes and it finally started slipping at 55k one day while hotlapping it at the dragstrip.
Put in a stage 3 max evil and it took a dump after 6k pampered miles (defective band). Now have a level 4 FLT, hopefully it way outlasts the max evil unit. If it lasts as long as the stocker (25k well modded miles) i'll be happier than a pig in ****.
Old 11-02-2006, 09:18 PM
86MonteSS's Avatar
this is a very appropriate thread. mine literally took a **** on me ten minutes ago.
Old 11-02-2006, 09:21 PM
Tech Resident
ChocoTaco369's Avatar
it'll be dead real quick. RPM's kill 4L60E's faster than anything. if you touch your shift points, say bye bye to the tranny. i'd give it 2 months tops if you daily drive it and go WOT regularly. GM rates the 4L60E at a max shift RPM tolerance of 6,000 rpms. in reality, the rev limiter is set slightly higher, but 6,500+ rpm's is a death sentence. start shifting at 6,800 rpms and it's a gonner.
Old 11-02-2006, 09:36 PM
1 SiCk Ws6's Avatar
still going at 87k
Old 11-02-2006, 09:44 PM
spare tire's Avatar
After the STS and stall converter my tranny only lasted 2,900 miles when it started to slip shifting into 2nd gear. The car only had 78k on the clock
Old 11-02-2006, 11:39 PM
texasreb18's Avatar
mine went at about 90k, had the mods in at 85k
Old 01-30-2007, 05:13 PM
usd2sing's Avatar
subscribed..curious
Old 01-30-2007, 06:36 PM
382WS6's Avatar
I drove my stock tranny for almost 40000 miles AFTER I had the 383 installed (which went in at 62000). I put a 3200 stall in it and it didn't last a month. In fact, I just blew the rear sprag and smoked 3rd and 4th again! I pick it up in an hour and then it's a guessing game as to how long it'll last again.
Old 01-30-2007, 07:03 PM
OOZ28's Avatar
2000 Z28, Just lost 3rd and 4th @ 69,000 miles, and Im pretty pissed off. Ohwell, I guess its a good excuse to get that stall I was wanting
