can the engine handle it?????
Old 11-02-2006, 07:11 AM
hesham's Avatar
Default can the engine handle it?????
hi every one i have a gto and my project will be very big and i whant to know if my engine will handle this kind of power and what should i do if not?
lq9 6.0 completly built (porged pistons, conecting rods, arp studs.....etc.
lsx fast 90 / 90
mti stage 2 heads (i may change them to et 265 as soon as they replay to my emails)
avo twin torbus
msd cois
x5g3 cam
asp pully
zex fogger system 300 hp
nos nosel 125 hp
boost cooler (water/meth inj.)
my trany was biult and my rare end to from bmr
so can the engine handle this kind of power?
Old 11-02-2006, 07:32 AM
caindo's Avatar
you plan to put this to the ground how?
Old 11-02-2006, 07:35 AM
hesham's Avatar
full slick
Old 11-02-2006, 10:46 AM
hesham's Avatar
up
Old 11-02-2006, 07:58 PM
hesham's Avatar
any one?
Old 11-03-2006, 04:36 AM
EPP
EPP's Avatar
I don't see why the engine can't handle the power, provided you have the fuel system for it, and a good tune. Bob
Old 11-03-2006, 06:48 AM
kp
kp's Avatar
With twin turbos and a 300hp fogger I'm pretty sure you will need someone to follow you around with a large enough cardboard box to fit most of the engine parts in.
Old 11-03-2006, 08:14 AM
hesham's Avatar
i have 2 welbro 255 intanke and one Aeromotive Pro-Series inline with a Free Flow Rate: 1,000 pph
and 70 lb inj.
Old 11-05-2006, 09:35 AM
venom ws7's Avatar
he is planning of running 20psi+ with 400 shot
Old 11-05-2006, 12:10 PM
99SS-T's Avatar
If u plan on using the stock crankthat will not put up with the kinda power ull be makeing. Im not sure if the twin intanks and that inline will be enough fuel. Im not sure how it works when u have 2 pumps in sequence. Im absolutely positive ur gonna need injectors about 2x as big as the ones u have.
From the sound of it ur gonan be makin about 900-1000 rwhp with out the nitrous. And then u plan on spraying 425 ontop of that. GL!!!
John
Old 11-05-2006, 12:31 PM
TransAm6383's Avatar
John
I dont think any engine parts will handle that kind of power. Plus either the turbos or the nitrous would be pointless. Use one or the other.
Old 11-05-2006, 04:15 PM
hesham's Avatar
guys dont forget that all the internals of my engiae are forged plus the crank 4" .
if i make the fuel pres. 90 i can make my injetors works as 85 lb @ 87psi
Old 11-05-2006, 04:30 PM
SuperZ's Avatar
learn to type buddy... and Ill believe this etup when i see it.good luck
Old 11-05-2006, 04:40 PM
hesham's Avatar
lol i see that i am not the only one who must learn
anyway i will post sum pic. as soon as i finish
thanks
Old 11-05-2006, 05:38 PM
Kraest's Avatar
Originally Posted by hesham
avo twin torbus
A twin tour bus? You must need alot of room to carry all of those fragmented parts when you blast 425 hp of nitrous at a TT setup.
Old 11-05-2006, 05:53 PM
hesham's Avatar
will please answer my q. only and dont be
thanks every one
Old 11-05-2006, 05:59 PM
Rock_Daddy's Avatar
You might have a head lifting problem. I don't think most run just the amount your talking let along on top of boost.
Old 11-05-2006, 06:04 PM
hesham's Avatar
ok guys give me some tips and expl. for them.
please
Old 11-05-2006, 06:08 PM
Rock_Daddy's Avatar
I'm no expert but I'd say just from the experience on this site from seeing what everone does it forget the spray and just go all turbo. People can get as high at 1500+ without spray so you don't need it. If you want big, focus on what it takes to meet your goals on turbos alone. What is yoru HP goal anyway?
Old 11-05-2006, 06:13 PM
hesham's Avatar
1200 - 1500 hp
Quick Reply: can the engine handle it?????
