Rear end question
Rear end question
A friend of a friend is selling a rear end. He claims it is a 12 bolt, but I am not so sure it is. He said it came out of a 3/4 ton pickup, but it only has 10 case bolts.
Can anyone tell me any way to verify if it is truely a 12 bolt or if it is a 10 bolt?
Originally Posted by Tainted
mooser or strange 12 bolt with 1/2 studs, the better rear end cover, 33 psplien axles and all the goodies
Originally Posted by BA98TA
so in your opinion what is the best way to go for a built rear end?
you can also find other 9" in things like torinos, lincolns, mustangs, vans, tbirds and so on from the seventies and eighties.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by LSXNV
without spending the big bucks? find a 9" ford out of an early ford pickup. you'll have to do some work getting it set up for your car, but you can take pride in your rear.
Originally Posted by MeentSS02
The 12-bolt designation doesn't come from the case bolts - it comes from the number of bolts on the ring gear.
Originally Posted by orangeapeel
Thank you Steve. It is just like people measuring width of a Ford 9" housing. Once again. Ring gear.
