Stock crank
Old 11-04-2006, 10:16 AM
whywhine's Avatar
Default Stock crank
How much hp can a stock bottom end hold up too and can you help it much with better bolts ?
Old 11-04-2006, 10:17 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
1200 at the flywheel for the crank.
About 500rwhp is the max I would take the stock hypereutectic pistons.
Rod bolts are always a good idea. They are a rather weak link in the bottom end. Rods are good to around 550-650rwhp.
Old 11-04-2006, 10:56 AM
GuitsBoy's Avatar
+1
good rough estimates here.
Old 11-04-2006, 03:19 PM
whywhine's Avatar
Thanks for the info fellas !
Old 11-04-2006, 03:22 PM
brad8266's Avatar
Therer are guys running 9's on the stock block. The weak links are the rod bolts and the piston ringlands. The crank can take about anything.
Old 11-04-2006, 03:53 PM
whywhine's Avatar
That awsome,sum rods and pistons and i can fly!!
Old 11-04-2006, 03:55 PM
whywhine's Avatar
What rods and pistons are good ?
