rear whines like a bitch
Well it all started a few months ago when i destroyed my stocker 10 bolt. and let me say I really blew it up good, broke the ring gears teeth off (all but 4) and the pinion gear actually blew a hole THROUGH the case making a wonderful 10 inch hole and that pinion gear is still to this day out somewhere on that lonely country road
AnYwHo
when i blew my stocker up we replaced it w/ a v6 rear end out of 98+ camaro and it whines like a bitch! anyone think some fresh lube and additive would help out? we obviously replaced it when we put it in but only put in 1 bottle of lube and there was a shitload of the gear grease in there. I figured since tis been like 2k miles a fresh change may help out the whining....
Any thoughts on this?
AnYwHo
Sounds like the carrier bearings may be bad.
Mine whined like a bitch unti I removed the cover and saw nothing but shavings on the magnet. Pulled the carrier and this is what I found.
Originally Posted by Tainted
well see, we ahd the cover off and relpaced the axles and everything and the stock bearings looked fine so we didnt mess with them. but as soon as i started driving it it whines. no matter what speed, acceleration or deceleration.
