what cam for a nitrous 408?
Old 11-05-2006, 08:36 PM
Lurius's Avatar
Default what cam for a nitrous 408?
Well I am starting to look around at what cam should go in the 408 im building. I was lookign at the thunder racing 224/227 .563/.569 114lsa but am unsure if this is large enough for the motor. I have heard some people talk about a cam being too small or too large for a 408. I barely speak cam language so would appreciate some help! I will be driving the truck daily and drivability will be an issue. Tranny is an auto as well. As for emmissions, I am fairly certain if need be I can pass one way or another, but this beign texas, I dont think it will be too hard either way. I will likely only be spraying about 150 shot, maybe sometimes a 200, and compression will be around 10-10.5:1 in the end.
Thanks a lot guys,
Lurius
Old 11-05-2006, 08:39 PM
ArrestMeRed99Z28's Avatar
that cam will be way to small for your application. I'm not sure how the Texas Giant is for streetability, but it's the only off the shelf stroker cam that I know of, I'd have my engine builder spec me a custom cam to fit the intake, heads, and compression that I was going to end up with. Good luck with your build.
AJ
Old 11-05-2006, 09:02 PM
Lurius's Avatar
AJ
Oof, that cams pretty big. Was thinking maybe high 220's or low-mid 230's for the intake/exhaust durations. Anyone else got ideas?
-Lurius
Old 11-05-2006, 09:27 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I would look in the higher 230's range. Rule of thumb when chosing a cam for a 346 is add 10 to the duration for that particular st. So your 224/227 would be a 234/237. That still seems like it is under cammed.
Old 11-06-2006, 12:32 AM
forgedbluess's Avatar
Yea thats a really small cam for a 408. Im doing a 370 and looking for a 240/250 cam but im looking for ever bit of hp i can get to make it to the 9s.
Old 11-06-2006, 04:44 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
And you aren't doing it with this: Forged 347, rossler th400, 4400 nitrous stall, transbrake, 300 shot of juice and stock rear end with slicks and skinnies....because? Stock 10 bolt?
Old 11-06-2006, 06:41 AM
Z'mnypit's Avatar
230's is still way small. Ive got a Comp 244/248 .612/.615 113lsa and its still a little small, but I like it. Made good numbers on the bottle also.. There are 3-4 other people on here running the same cam also making good numbers
Old 11-06-2006, 07:14 AM
slow trap's Avatar
in that sweat hog of a truck it will take some decent bottom end tq to get it moving off the line off the bottle so i'd say something like a 236/242 or so would be a decent performer n/a and on the bottle.how often are you going to be driving it on the street and how much are you going to be racing it ?
Old 11-06-2006, 01:42 PM
No i have a rear end at the house now i just decided to build something that will handle a 2 stage nitrous setup like i want.
Old 11-06-2006, 02:58 PM
Lurius's Avatar
Mostly driving daily. To/from work/school. I dont get to the track much now, but thats ebcause I havent made much of an improvement lol. Once I get the motor together and get a built tranny i'll likely be going 2-3 times a month.
When yall are saying undercamed, do you mean it wont be makign nearly its full potential, or that it would not run well with such a small cam? Im alright with losing a little performance since it is a DD, but I want it first and foremost to run good and be a reliable engine that I can depend on to get me to work and school. I figure even losing some of its full potential it will still make decent power all things considered.
Thanks a bunch for the input guys, its really helping!
-Lurius
Old 11-06-2006, 06:24 PM
slow trap's Avatar
something in the 22x range in a 408 will be out of breath pretty early in the rpm range and your tq will not be much higher than a slightly bigger cam so your useable power will be less with that small of a cam.
Old 11-06-2006, 06:55 PM
99blancoSS's Avatar
24x/26x
Old 11-06-2006, 07:19 PM
getusum's Avatar
Now it's time to call the MAN on this topic!!!!! Yo Patric.......this guy can use your help....lol.....he is da man
Old 11-06-2006, 07:22 PM
NOZR1's Avatar
I went with HPE's Big E cam in mine. I should know in a few weeks how I like it.
Old 11-06-2006, 09:54 PM
Lurius's Avatar
Would a 240's range cam be daily drivable you think? This is the only thing im afraid of lol. I dont want to end up with a track only truck for my daily driving haha.
-Lurius
Old 11-06-2006, 10:25 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
-Lurius
In a 408? yes.
Old 11-06-2006, 10:36 PM
cws T/A's Avatar
T REX / 408 http://video.ls1tech.com/category/Ca...a3ad663d29.htm
Old 11-06-2006, 10:39 PM
99blancoSS's Avatar
Yep, with a 408 you've got the cubic inches to run a 24x/26x cam and have it be perfectly streetable
Old 11-06-2006, 11:03 PM
cws T/A's Avatar
daily driver 408 in a heavy truck , build for torque , horsepower will follow
Old 11-07-2006, 08:02 AM
Lurius's Avatar
I like the sound of that GTO in the vid you linked. Especially that 6.7L badge! I had been thinking of the same thign to go on the tailgate. Anyone know where he got it?
Would yall reccomend getting a custom grind cam? I was thinking of just telling them what im building, what I need and seeing what they come up with.
-Lurius
Quick Reply: what cam for a nitrous 408?
