Need a favor from all of you guys with camed lt1's
Im getting a cam kit from Bauer racing. The kit includes: cam, springs, retainers, locks and Locators. I know what else i need put and confused on what EXACTELY what to buy. I know ill do a timing chain, injectors, lifters, pushrods, gaskets. Anything else im missing? And can you guys give me part numbers on exactely what parts. Also ill be gettin some of this for x-mas and ill tell the g/f to just come and look at this thread to get part numbers so she can suprise me. Thanks all!
Internet Mechanic
Being a Bret Bauer cam, he is going to want you to get Morel Lifters, and your going to have to measure the proper pushrod length, he used a gutted out Comp R lifter. It worked mint. As for timing chain it depends on the opti, if its non vented either you upgraded to vented OR, you get a single chain not the double roller/EWP set up. I elected for the Lunati chain which worked fine, it still stretched after 1k miles..... so keep that in mind
Originally Posted by Taubr Unit
i got a 94z, so non vented opti and i have a electric water pump.
95 Timing Cover= GM p/n#12552426
95+ Optispark = GM p/n#1104032
If you get the cloyes double roller, you may have to do some clearancing to the inside of the timing cover. I know I did anyway.
The funny thing is that it appeared to fit fine, with no clearance issues that I could tell. Then about 500miles after installing the motor, my crank seal walked out of the cover (BBC crank seal,cover machined too loose). When I went to replace the timing cover I noticed the chain had been rubbing on it. So I grinded the general area down with paper rolls on a air grinder.
I had to take about 1/16" out of the area the chain rides near all the way around. I then ran the motor and removed the cover again to make sure it was no longer in contact.
