QA1 doubles or AFCO's???
Originally Posted by Schurters LT1
how do the strange compare to the QA1s ??
FWIW, I've discussed this with MADMAN. He doesn't care for the QA1s, he said they were unpredictable to different inputs.
He rated AFCO #1 and Strange as his 2nd choice
Can you do the coil over with all of them ????
i really would like to have to coil over just so i can adjust ride height.....with all the extra wight in the front from the blower and intercooler....
Madman said that the AFCos are the best hand down.....but the $$$$$
Is there anything wrong with the QAIs....or should i look at the strange ?
thanks
thanks
thanks
thanks
My QA1's work like a champ. I adjust them and they do what there suppost to do. I respect Madman and all the work he does. But I disagree with his commment. Maybe he had a bad set or something was wrong with the valve in the shock.
LS1Tech Sponsor
If you are going to the double adjustables shocks then either the AFCO or the Strange is the way to go. The QA1 vavling isnt right and the piston is too small to work properly on extension. I have had quite a few customers try them and we have taken them off and replaced them with a quality shock and the car has reponded.
I have had both the AFCOs and stranges on the back of my car. The AFCOs are nicely made but they really need to step into the 1960's and at least put some clicks on the adjuster on top so you know where you are for that kind of money, 1/16 of a turn makes a huge difference on them.
I would buy the Strange DA rears to be honest, but to be really honest none of them worked any better then the 50.00 50/50 CEs I'm using now lol - granted 1.28 60's for a 3450lb car isnt all that great..
