Forced Induction - 6L manifold kit with twin T61s good idea?
CHRISPY
11-07-2006, 06:44 AM
Hey guys,
Just wondering if anyone has built a twin setup with two T61s? Those turbos are cheap and you could mount them in the front corners of the car and still keep stock fans etc.
Has anyone does this? I think it'd work pretty well. You could even do oval 2.5 sections under the Kmember and keep the AC if you wanted.
Similar to this setup...
http://www.trtturbo.com/images/race_car_001.jpg
Thoughts?
:cheers:
smokinHawk
11-07-2006, 07:31 AM
i dont see why you couldnt, just depends how much power you want to make with the two T61's
also things to consider is the oil drain return.
FastKat
11-07-2006, 08:05 AM
Hmm, kind of rwhp are you looking for? Also, good point... I think that setup would require some sort of oil return pump.
CHRISPY
11-07-2006, 08:10 AM
Looking at the compressor map for the T61 and consumption chart for a 346 I think you could make ~800RWHP at 2 bar with twin 61s at 6800rpm on a stock cubed motor.
You'd need a scavenge pump but that is no big deal :) (I wonder if you could Y the two turbo drain back lines to a single pump?
DrTurbo
11-07-2006, 09:15 AM
Go bigger then 61's. I would go with a pair of 66's...hehe
CHRISPY
11-07-2006, 09:50 AM
61s are so cheap and plentiful though :) For a street car wouldnt twin 61s, 1.8-2.0 bar be quick spooling and make great power? If it were a track car off a Tbrake I'd definitely go bigger :)
This would be for a six speed street car on a drag radial.
:cheers:
LS2Camaro
11-07-2006, 10:58 AM
:headbang: :headbang:
Now thats what im talking about, Go big or go home.... I wounder what a pair of the soon to be S-91's would do? Hmmmm
DrTurbo
11-07-2006, 11:03 AM
lol, call some of the Outlaw 10.5 cars, since we have a few folks on the waiting list already....haha
LS2Camaro
11-07-2006, 11:06 AM
Are the S-91's the same size as the S-88's? What is the HP rated on the S-91's?
DrTurbo
11-07-2006, 11:12 AM
Yes same size, and right now the rating is TBA, but I suspect from the flow #'s I see on the e-mails being passed around "shhhhhh ;)" It should top the S88, by more then another 100hp. :)
smokinHawk
11-07-2006, 11:37 AM
so you guys were successful in stuffing a 91 wheel in the the GT42 frame?
ls1king000
11-07-2006, 11:48 AM
I was planning on twin t61's. Last minute changed to t66's but, I plan on more cubes later. I have a totally different idea of turbo placment though. INTDM8 running 61's I believe.
DrTurbo
11-07-2006, 12:38 PM
I'm not....only thing I'm sucessful stuffing is my girlfriend....lol :devil:
But I think Jose and Jason have the turbos covered....lol
