Stock Injectors. How much Horsepower can they produce.
Old 11-08-2006, 08:58 AM
ZEX-Z's Avatar
Default Stock Injectors. How much Horsepower can they produce.
How much horsepower can you get out of the stock LT1 injectors?
Old 11-08-2006, 09:07 AM
GIZMO's Avatar
500+ fwhp at 50 psi in race applications N/A.
Old 11-08-2006, 10:03 AM
Formula350's Avatar
50PSI is pushing like 27#+ through the injectors isn't it?
Old 11-08-2006, 10:17 AM
LT1nitrouZ's Avatar
with stock fuel pressure you are pushing your luck over 400 fwhp
Old 11-08-2006, 11:00 AM
siniSSter's Avatar
Try http://www.rceng.com/technical.htm
Its got a lot of useful caculations to further help your F.I knowledge
Old 11-08-2006, 11:46 AM
foggedz's Avatar
My stock injectors were at 95% duty cycle at 330hp.
Old 11-08-2006, 12:33 PM
C_Rules's Avatar
i used the first formula and for a 500 hp engine it calculates 39lb injectors.
i currently have stock injectors and i have 309rwhp. the tuner said those injectors were fine and my a/f ratio was good. i have a new cam and im going with the spray so im guessing i will have near 500rwhp with a 150 shot. i guess according to that formula i'll need 39lb injectors which i dont think they make. so i might have to get 42lb. injectors. does that seem right?
Old 11-08-2006, 12:49 PM
siniSSter's Avatar
@ 309 hp you'll be fine with the stock 24lb injectors. Although for the nitrous shot you may want to upgrade to 30 or 36 pounders..I have 624 hp to the wheels on spray w/ 36 pounders...seem to work well.
Old 11-08-2006, 01:58 PM
buffman's Avatar
IMO I dont like the idea of spraying on stock injectors. Well if they never lock you're okay, but if they lock, stock injectors lock closed and not open like most aftermarket injectors
Old 11-08-2006, 03:04 PM
foggedz's Avatar
If its a wet shot they shouldnt have any problems locking.
Quick Reply: Stock Injectors. How much Horsepower can they produce.
