Drag Racing Tech
Bottoming out on Launch...What to do?
Old 11-09-2006, 10:57 AM
BADSZ28's Avatar
Default Bottoming out on Launch...What to do?
OK, so I can see I am hitting my bump stops in the rear on launches. What can I do to prevent this and get a better 60' maybe? Do I need shocks or springs? I have stock peices right now.
Old 11-09-2006, 12:29 PM
Old Geezer's Avatar
Start with a good set of dbl adj shocks, and tune from there.
Old 11-09-2006, 01:28 PM
Coal Mining Director
onfire's Avatar
I would start with some LCA lowering brackets first....you're squatting....drop the front of the LCA to the lower hole and watch the difference a little anti-squat makes.
Old 11-09-2006, 01:51 PM
BADSZ28's Avatar
I already did that. Have been for years. Still squats. Guess I should have mentioned what is done already. LCAs, LCA brackets, fixed* TA, !front sway bar. All else stock for suspension. It only pops the driver tire on good launches. Which is good I guess. But it just squats too hard.
Old 11-09-2006, 02:04 PM
Old Geezer's Avatar
Talking Like I said B4...
If you don't want to spend the $$ for a set of adj shocks, at least try some new, hi quality, stock type shocks.. 4 yr old stockers were virtually junk, when new.
Old 11-09-2006, 02:05 PM
ls1_doc's Avatar
What about qa1 adjustable shocks ?
Old 11-09-2006, 02:14 PM
BADSZ28's Avatar
Well this is my question, do I need shocks? Will shocks stop the squat? It is not a money issue yet, just need to know what needs to be done to stop squat. Right now I am looking into QA1s and Competition Engineering units. Do I NEED fronts? What are the bennefits to fronts? The suspension drops fine although when I brake the nose dives pretty hard so I know I need them eventually. Thanks for all the input so far. Please keep it coming.
Old 11-09-2006, 06:26 PM
94z28L's Avatar
if you dont wanna spend the money on a set of Qa1's just get the CE's they're pretty cheap
Old 11-09-2006, 07:28 PM
1QuickT-A's Avatar
buy some QA1 shocks or the CE shocks if your a cheap ***... if that doesnt stop the squat put a air bag in the right rear spring or buy an anti roll bar for the rear..
Old 11-09-2006, 07:39 PM
94z28L's Avatar
i like my anti-roll bar
Old 11-10-2006, 12:50 PM
raceme9s's Avatar
just cut off the bump stops
Old 11-10-2006, 12:55 PM
CARTEK Racing
WS6TransAm01's Avatar
Im confused why this is happening to you. I am leaving the line with the front wheels a foot or more in the air, so all the weight is on my rear shocks/springs and I am not bottoming out. I have my stock shocks and springs that came with the car in 2001 with 65K Miles on them. Never changed them. Are you lowerd? Yeah your car is 360lbs, maybe its a bit too heavy for the rear springs to handle all the weight? I would think that some new OEM Shocks andf springs should be able to handle the weight transfer.
Old 11-10-2006, 01:00 PM
raceme9s's Avatar
get a set of adjustable shocks all the way around qa1 will work fine.
you can adjust the shocks for the squat, but you want the car to have weight transfer so that you can get a good 60ft, we ran 6 turns in the front and 3 in the rear with the qa1s and where going 1.28 60fts [we cut the bump stops out]
Old 11-10-2006, 01:58 PM
BADSZ28's Avatar
The 9" hits the floor so I do not want to cut-out the stops. I have pretty good weight transfer. I pull one tire and still bottom the rear suspension at 3600lbs+. I have launch pics that show the transfer. I have cut a 1.51 60' so far. I watched a vid of my car and you can see the car come down, then bounce up and come back down.
Old 11-10-2006, 08:14 PM
V6 Bird's Avatar
The cheapest and smartest thing to do is remove the bump stops....doh!
Then take a BFH and clearance the body where the 9" hits...The car needs to sit on top of the tires...let it squat. shocks will only control soo much.
Old 11-10-2006, 09:01 PM
1BADAIR's Avatar
you don't want the rear to squat. some adjustable rear shocks will fix it.
mine stays flat when the rears are on 5(5way) but look at my sig with then set on 2
Old 11-11-2006, 06:14 AM
tektrans's Avatar
How much gas is in the car when you race?
Old 11-11-2006, 03:21 PM
BADSZ28's Avatar
between 1/4-1/2 most of the time.
Old 11-11-2006, 03:23 PM
1BADAIR's Avatar
cars that came with 17's have an aluminum spacer under the jounce bumper. you can remove it.
I haven't seen a non lowered car hit them though
Old 11-11-2006, 03:53 PM
BADSZ28's Avatar
Just a Z28 so no spacer. The only lowerring done was removed the spring perches with hose.
Quick Reply: Bottoming out on Launch...What to do?
