65lb motron help!!!
Old 11-09-2006, 02:29 PM
98turbls1's Avatar
Default 65lb motron help!!!
Hey guys, I installed some 65lb motrons in my car because I'm installing the D1SC tomorrow...Anyways, do these need to be tuned to run right?? It's running like hell but I thought it was because it didn't have any fuel at first...Anybody that can help would be appreciated...
Old 11-09-2006, 03:41 PM
jv_Z28's Avatar
Your PCM still thinks the old injectors are in so it's not going to run right, I wouldn't run the motor at all. When you get the car tuned with your D1 the tuner will fix the injector problem.
Old 11-09-2006, 03:42 PM
98turbls1's Avatar
That's what I'm thinking too...I'm swapping the stock injectors back in... I just wanted to get this out of the way...Ehhh... =(
Old 11-09-2006, 03:44 PM
jv_Z28's Avatar
Sorry dude. Are you going to tow your car to get it tuned when the D1's in? As a suggestion- I would.
Old 11-09-2006, 03:59 PM
98turbls1's Avatar
I'm going to install it but not have it hooked up entirely until I get to the tuner's place...
Old 11-09-2006, 05:35 PM
Ed Blown Vert's Avatar
You won't be able to run the 65 without a tune. Its dumping to too much fuel.
Old 11-09-2006, 06:02 PM
98turbls1's Avatar
yeah, I can smell it ed... Are you available tomorrow evening to throw a tune on??
Old 11-10-2006, 12:13 PM
MIGHTYMOUSE's Avatar
you should have done more research first, this is an obvious mistake that can damage your engine. you are spraying more than twice the fuel necessary into the engine, and the computer can only pull back 25% of that on its own
injectors are run by the computer.. change injectors = tune the computer, the bigger the change the more serious the symptoms will be.
the only other thing you could do is adjust the fuel pressure down significantly temporarily until the car is tuned, for this you would need an external adjustable regulator.
Old 11-10-2006, 12:15 PM
98turbls1's Avatar
I already changed them back this morning... I didn't want to run them that way but I'm off to do the D1 install and then to tune....I'm not going to have the blower hooked up all of the way until the tune and that's when I'm throwing the 65lbers back in...Thanks for everyone's input..
Old 11-10-2006, 12:52 PM
I think so. Don't worry I won't charge you too much.
Old 11-10-2006, 02:51 PM
JD_Z28's Avatar
Only your first born child
Old 11-11-2006, 02:11 AM
98turbls1's Avatar
Well I really appreciate that Ed.. =)
Old 11-13-2006, 06:19 PM
BoostedWS7's Avatar
i would seriously check your oil for the smell of gas. if it does smell and is blacker than normal... change it!
