d1sc intake hat
d1sc intake hat
im just curious,is the aluminum 4" short radius 90 we are looking for about the same as a 4" street copper 90? or a 4 " street pvc 90?(common plumbing parts) just trying to get a size bearing. thanks
I dont know about the aluminum elbow but I used a PVC elbow to try it. Its the one used for vent fans and not the plumbing version - its a super tight radius and will fit without trimming anyhing. I used that and 2 45* to make a 'J' shaped pipe. I'd take a pic but I threw it away a while back after I was done experimenting with it
Inlet air filter update:
We found a good way to keep the air filter out of harms way, and the filter is really isolated from rain the way we positioned it, as shown in the pictures. Bob
Bob...pics are from a "D" series ProCharger not the "F" series correct? Also looks like an aftermarket radiator/fan assembly...? I see its moved considerably forward from the stock location with the bottom support cut away quite a bit too. Yep, I'm still tryin' to get something worked out on mine...major PITA. That set up won't work for me...
Originally Posted by Moparnos (The SLP Guy)
kinda looks like the one i made awhile ago.
Yes, it is a D-1SC. We had the factory radiator in there until we noticed the ends started splitting, so we installed a be Cool radiator. Stock fan assembly, although we added a Spal 9.00" fan to it. The bottom support was trimmed out more for the way we had the inlet plumbing routed before the current configuration. Bob
