d1sc intake hat
Old Nov 11, 2006 | 09:56 AM
ZDOG's Avatar
Default d1sc intake hat
im just curious,is the aluminum 4" short radius 90 we are looking for about the same as a 4" street copper 90? or a 4 " street pvc 90?(common plumbing parts) just trying to get a size bearing. thanks
Old Nov 11, 2006 | 11:34 AM
kp's Avatar
kp
I dont know about the aluminum elbow but I used a PVC elbow to try it. Its the one used for vent fans and not the plumbing version - its a super tight radius and will fit without trimming anyhing. I used that and 2 45* to make a 'J' shaped pipe. I'd take a pic but I threw it away a while back after I was done experimenting with it
Old Nov 11, 2006 | 01:16 PM
ZDOG's Avatar
because hell if a 4 " pvc 90 will fit its pretty damn cheap. i got to get my lazy *** under there to look. kp, is your car a stick or auto?
Old Nov 11, 2006 | 01:51 PM
kp's Avatar
kp
Like I said the regular 90* PCV water pipe wont work but the PCV 'vent' 90* will work - both are at home depot.
I have a TH400.
Old Nov 13, 2006 | 11:11 AM
EPP's Avatar
EPP
Smile
Inlet air filter update:
We found a good way to keep the air filter out of harms way, and the filter is really isolated from rain the way we positioned it, as shown in the pictures. Bob
Old Nov 13, 2006 | 12:22 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
kinda looks like the one i made awhile ago.
Old Nov 13, 2006 | 04:04 PM
Jimmy P's Avatar
Looks VERY similar.
Old Nov 13, 2006 | 06:06 PM
DJ's Z's Avatar
Bob...pics are from a "D" series ProCharger not the "F" series correct? Also looks like an aftermarket radiator/fan assembly...? I see its moved considerably forward from the stock location with the bottom support cut away quite a bit too. Yep, I'm still tryin' to get something worked out on mine...major PITA. That set up won't work for me...
Old Nov 13, 2006 | 06:56 PM
WAHUSKER's Avatar
That screen would be a good idea....if you could build an air damn to keep the hot air from the eng & rad out. I gained 0 with a similar type of setup.
Old Nov 13, 2006 | 07:59 PM
EPP's Avatar
EPP
Smile
Great minds must think alike... Chip, who works for me, came up with our installation on his own. Bob
Old Nov 13, 2006 | 08:03 PM
EPP's Avatar
EPP
Smile
Yes, it is a D-1SC. We had the factory radiator in there until we noticed the ends started splitting, so we installed a be Cool radiator. Stock fan assembly, although we added a Spal 9.00" fan to it. The bottom support was trimmed out more for the way we had the inlet plumbing routed before the current configuration. Bob
