Post winter photoshop
Shirley Temple Drinker
I'll see about it. I'll have to look under the car to look for a way to even do it, if theirs enough clearance under the rockers and pinchweld to do it the right way, and try to find some tips that would work, it will be done right and clean or not at all.
BTW yea the chops not very good at all, its just a quick 15 min thing, and I defiantly don't have the skills most do on here.
The 15's and tint are for sure, the lowering springs are iffy, going to have to see how it looks at stock height with the fatties and the tall walled skinnies first, the side exhaust still needs a bit of planning, it would be a early spring thing. Would it look better going out each side, or just the passenger side?
I'll have to worry about SFC clearance as well..
Originally Posted by BAD *** TA WS6
Side exhaust won't work there. Not enough room, you'll have to go underneath the rocker panel, and lowering with that setup will have no clearance.
Stripe is cool...
You won't be able to find Weld Prostar XPs. I'd bet money on it...
Stripe is cool...
Not looking for xp's, getting 15 inchers, photoshop's just a little skewd.
