Whats a Smogable H/C setup?
I live in cali, and i am saving up now for some heads and a cam. Wondering whats a good setup smogable in cali thats can make over 400RWHP. I currently have a 2002 SS with LT pacesetters w/ catted y-pipe, GMMG, Lid and a pro 5.0. Now what set of heads can I use with a good size cam. Thanks guys.
Originally Posted by SSmokeDaGT
You cant but its pretty easy to have those overlooked. Where can i find that setup at?
I was thinking about going with the 224/224 112lsa Thunder racing cam. Whats a good set of heads for that? Or is it easier to get mine ported?
so thats what help i can offer for now and up for your question
Get the heads of your choice milled as much as you can without having them knock with that 91 octane that you guys have to deal with. This will make a more complete burn, hence less unburned hydrocarbons coming out of your exhaust. AFRs are a great choice if you've got the $, PRCs or Patriots are great bang for your buck. Look for Cali people in the dyno sections, see what setups they are running and how they get around emissions.
I also have a 224/224 .581/.581 for sale, with a sale pending, PM me if you're interested and I'll let you know what happens with the sale.
Good luck
AJ
Good luck
AJ
Hows some PRC stage 1 heads from Texas Speed and a 224/224 112lsa? And advice or comments? Im on a tight budget and im going to install myself with some help.. The whole setup would cost less then $2000 with gaskets and all...
On a 112 LSA, you get 4 degrees more overlap than with 114. I would look for others who have passed smog with the 224/224 cam and see what LSA they run. More importanly, how much tuning was required to get it to pass.
You can always tweak the tune, but it's tougher to swap the cam out if you go too much. The same cam on a 114 will be quite comparable.
Im probably gonna order the package at the end of the month.. Im excited.. With all your help i decided to get the head&cam package texas-speed offers. With the 224/224 114 lsa
http://texas-speed.com/shop/item.asp...d=203&catid=47
Hey I like this... man just hard to get past the dollars though..around 42$/HP
thunderracing cheater head/cam package
Oh i currently put down 336rwhp.. Will this package put me at or above 400rwhp? The timing chain, ls6 ported oil pump and the gaskets kits, should i get those as well?? I was thinking while im there i might as well do the timing chain and oil pump.
I live in California and will be doing the smog thing in about 2-3 weeks. I will be running 219/221 on a 112 with .590 lift and PRC terminators (205). If you're running an automatic don't go too radical on the stall - my 3600 wouldn't fly on the roller test at 2500. Good luck to us both. I will post the results when I pass...
