TPS mod? Just had a thought
Old 11-13-2006, 12:14 AM
mvvette97's Avatar
Default TPS mod? Just had a thought
I was just thinking, what would happen if you drilled the two holes bigger on the TPS and advanced the TPS up? Would the pcm think the throttle is open more than it really is and give it more timing off idle? The reason I thought of this is because on the 80s 5.0 stangs you could adjust the TPS so it would give it a tad more timing and fuel off idle. Didn't know if it would work the same way on these cars or not. Just a thought
Old 11-13-2006, 12:45 AM
5_02ls1's Avatar
Default bumpstop mod
do the bumpstop mod. just dont go any higher than 4.65 volts or it will set a dtc.i dont know if it helps any but its a free mod.
Old 11-13-2006, 12:46 AM
mvvette97's Avatar
yea i did that when i ported it.
Old 11-13-2006, 04:47 AM
300bhp/ton's Avatar
Why?
Just tune the car on a dyno, or buy EFI Live/HP Tuners if you want to alter the timing.
Old 11-14-2006, 01:10 AM
mvvette97's Avatar
It was just a thought
Old 11-14-2006, 08:54 AM
jmm98LS1's Avatar
Won't work. Once the tps voltage goes over .6v (IIRC) the pcm throws a code. It would have no effect on spark advance anyway, as that's controlled by a table in the pcm based on engine rpm vs manifold absolute pressure.
Old 11-14-2006, 09:30 AM
SUTTERERMAN85's Avatar
get a tune or tuning software
Old 11-14-2006, 09:54 AM
mvvette97's Avatar
OK, thanks
