LS1 rebuild
Old 11-13-2006, 02:33 PM
01CaMMMaro's Avatar
Default LS1 rebuild
im going to purchase a used stock ls1 from a junkyard and i wanted to know what parts should i replace? im putting in a torquer 2, 220cc PRC 5.3L stage 1.5 CNC ported heads from TSP, LS2 timing chain, ported LS6 oil pump, 7.4'' pushrods, and an underdrive crankshaft pulley. im also looking into putting on the ARP rod bolts and probably going to replace all gaskets in the areas that i will be working on. I will probably use the stock rockers from the engine ill be purchasing if they are in good shape. Is there anything else that i should be replacing?
Old 11-13-2006, 02:42 PM
NviouSS's Avatar
might want to throw in new lifters while you're at it
Old 11-13-2006, 03:27 PM
seawolf18's Avatar
Check all the main and rod bearings. Might as well, since the engine isn't in a car. +1 on upgrading the rod bolts. If its a pre 2001 engine, i'd put an ls6 intake on it.
Old 11-15-2006, 01:33 PM
01CaMMMaro's Avatar
ttt... thoughts anyone?
Old 11-15-2006, 02:37 PM
Asmodeus's Avatar
Old 11-15-2006, 02:41 PM
Has Unresolved Sales In Feedback/12 second club
notatruews6's Avatar
Good pistons mabe?
Old 11-15-2006, 03:01 PM
JTSLP559's Avatar
how much are you getting a motor from the junkyard for??
Old 11-15-2006, 09:59 PM
01CaMMMaro's Avatar
I havent even looked yet and i dunno if im gonna buy it from a junkyard or ebay or what. im not gonna go as far as replacing the pistons.
