PT4000 guys, quick ? for you....
Old 11-14-2006, 10:10 PM
Primered's Avatar
Default PT4000 guys, quick ? for you....
What are launching at? I haven't had a whole lot of time to play with different points yet, but so far the best 60 ft i've had is a 1.72 on a SI car with lt's, duals , lid, 3.42's and a tune leaving around 1800-1900. I tried a little over 2k and it spun. Some told me that 1.72 was not very good, so i'm trying to get a feel of what I need to do, launch off idle, stall it till the brakes are about to give?
Thanks
Old 11-15-2006, 10:52 AM
Yank's Avatar
Best is to get your tires hot and stall it up to as much as you can that is best power output for the PT converter
Old 11-15-2006, 04:29 PM
gillbot's Avatar
i cut my best 60's by launching off idle.
Old 11-15-2006, 04:55 PM
import slayer's Avatar
with my PT 4400 I can break stall it up to 3000 before the tires break loose
Old 11-16-2006, 08:21 AM
"All Motor 9 Second club member"
TXCAMSS's Avatar
My ST3500 liked to be stalled up as high as I could get it before pushing through the beams.
My PT4200 was not too sensitive to the stall rpm, but it did yield slightly better 60fts with a max rpm stall at the launch.
I pulled 1.42 60fts with it when I was a H/C and with the 383 stroker.
You definitely need a sticky tire to get maximum benefits from that TC.
Good luck!
Old 11-16-2006, 08:44 AM
GregWS6&z28's Avatar
2500rpms worked great for slow 1.6's and wheels up for me in my 3600lb car
Old 11-16-2006, 03:10 PM
Primered's Avatar
Damn, I thought a 1.72 wasn't that bad, you guys are making me feel like ****. I guess i'll go test it out again this weekend. Thanks for the advice guys.
Old 11-16-2006, 03:34 PM
I had consistent 1.8 60 foot times with a 2800 stall. I cant wait to go to the track with my PT4400.
Old 11-16-2006, 06:22 PM
gillbot's Avatar
i'm in the 1.6's off idle.
Old 11-16-2006, 06:29 PM
SEB
SEB's Avatar
I have a PT4400 & I launch at 2800 rpms & pull 1.57 60fts all day & my best is a 1.53 60ft
Also that is on BFG Drag Radials too.
Old 11-16-2006, 06:34 PM
Primered's Avatar
SEB, I know your car, i was out at the cruise too. I'm only making 308rwhp, no cam yet, just sitting waiting to go in.
Old 11-16-2006, 06:57 PM
i just looked at my old log of my best pass with a 3800 stall and I ran that on a 2800rpm launch also.
Old 11-16-2006, 07:40 PM
DrkPhx's Avatar
I average 1.5x's with a best of 1.51 on MT DR's on a well prepped track. Launch varies from 1200-2400 rpms with same results.
