heater core
heater core
so i have noticed as it starting to get colder here in oklahoma...that my heater really isnt performing to my standards!! lol
it does move air. but with the car warming up to 180* the air never really gets any warmer!! i was told i may want to check my t-stat first to see if it is stuck open.... and i think this could be part of, or "the" problem because my car has NOT seen 185*+ in a LONG time.
anyone have any suggestions? never done a heater core before. heard they are lots of fun though!!! lol i am of course gonna check the stat first...much easier and cheaper!!!
thanks guys!!
thanks guys!!
1) Check thermostat (just replace it, they're cheap)
2) Do jet flush on core to see if that works. If no, step 3.
3) Replace heater core. Make sure you also remove the A/C evaporator and clean the fins (use vacuum, brush). Reinstall everything. Enjoy heat.
3) Replace heater core. Make sure you also remove the A/C condenser and clean the fins (use vacuum, brush). Reinstall everything. Enjoy heat.
Yea mine sucks **** too. I assume I have a 160stat in mine, it only gets up to the first line on the gauge and I have ZERO heat. I wouldn't even call it lukewarm
Also there are vacuum lines that move the actuators and a cable to move the door in between the AC evaporator and the Heater Core. if the cable or the actuators go you can have problems with your HVAC system
Does anybody have directions (diagrams) on how to change a heater core in our cars? Also does anybody have more info on that TSB mentioned by UnitZ28?
Nevermind...
Nevermind...
Autozone.com > repair info > repair guides > under chassis electrical
Couple of tips- Remove the hoses while the core is still bolted down then take a shop vac and suck out as much coolant as you can, this avoids a big mess inside. cut a couple pieces of cardboard and place them on both sides of the new core while your jimmying it back in to place, to aviod damaging the fins. Make sure you reuse the foam gaskets or replace them with something similar, basically seal around the sides of the core so air goes through it not around. It is tight in there and will require some wiggling but it's not as bad as many other cars.
I have a 160 degree stat and never had issues with the heat. It blows plenty warm whenever needed. I dont know if you guys were saying that the low temp stat would be causing it or not.... if so, well, not in my car .
I'm sorry to interupt on your converstions but the unit that is in front of the heater core that you should remove is the evaporater core. It's what the cold compressed freon flows through in order to cool the A/C, I've seen them plugged up with hair to leaves from the trees to bugs.
I spent thanksgiving day fixing my heater, it never worked from the day I bought it (about 18 months). I pulled the hoses off the core and blew them out. The heater works great now.
Sara Lou
Sara Lou
