I Have Problems And Stuff For Sale
first off lets see if anyone can figure out my problems, i just put my LT4 blower motor in and after i broke it in i started beatin it around and anytime i take it past 5,500 to 6,000 it starts breakin up. any ideas? i dont have a blower on it yet. could it be time for a better ignition?mods are:: 383 Lt4 6spd,ported heads,9.5:1 comp,58mm TB,ram air,MSD coil,255lph pump,long tubes,stock opti,crower blower cam,comp is programed to this new setup.
also i started my car the other day and my security light didnt go out until 5 minutes later? is my key goin bad?
STUFF FOR SALE:: PICS AVAILABLE EMAIL ME
Forged 350 crank cut .010 under $250+S&H
Forged H beam 6" rods ground for clearancing $150+S&H
$350+S&H for both
BMR Tubular red lower control arms with grease fittings needs new bushings 30+shipping
CARPETED CUSTOM SPEAKER BOX CUT FOR (2) 12" SUBS
NEVER USED FITS IN THE TRUNK, SITS FLUSH WITH THE TOP OF THE TRUNK 100 LOCAL PICK UP
pass side headlight assembly (black) 170 shipped
HEADLIGHT+MOTOR 180 SHIPPED
6spd swap
low mileage 6spd trany
comes with 6spd pedals
slave cylinder
Fidanza aluminum flywheel used one summer($400)
McLeod street twin clutch used one summer($600)
B&M ripper shifter
white shift **** with built in button
will include top of center council
askin 2200 OBO id like local pick up if possible. it is still in my car so if you want a ride we can arrange it
a/c compressor 75 shipped
AIR PUMP 30 SHIPPED
$350+S&H for both
6spd swap
slave cylinder
B&M ripper shifter
AIR PUMP 30 SHIPPED
LT4 blower motor
Yes, I vote for Injectors.
Originally Posted by Formula350
I don't quite think you understand how confused I was by your wording. I couldn't imagine why you'd need to break in a blower motor, or even know how many RPMs it was spinning at.
+1 for the injectors
Wait, so you're running a motor set up for boost, but you're not running any boost?
I'd say it's because of just that. Motor wasn't made to run w/o boost. Cams are set up with boost in mind.
i have the computer programed for the motor without boost. i dont think thats why
