Kill Switch Rule??
Kill Switch Rule??
I know...I know...I should just get a rule book but, I never got around to it.
Anyway, what's the specific rule for cutoff switches? I don't plan on moving the battery to the rear. However, I've heard some people saying 9.99 and quicker in competition needs one no matter where the battery is.
Thanks,
Andrew
Thanks,
Andrew
Thanks,
Andrew
Thanks,
Andrew
Thanks Jay. I guess that's one more thing to add to my list.
It's getting awfully friggan expensive just to run in a 9.50 class.
is there any specific way it has to be done? a buddy of mine bought a car with one and it had the battery in the rear. after further inspection, the ground wire is ran through the kill switch. it works like a charm, as its supposed to.
NHRA rules it has to be the power wire[plus side of batt] thhat runs through the switch,and also dont forget the alt wire also has to be run to the switch,other wise car will stay running when switch is off, bob
Originally Posted by NRC-Motorsports
your buddy,s car is wrong,as per
Nope!
www.madelectrical.com
Any time the battery is relocated to the rear of the car there has to be a kill switch. If you do not have a wall between the driver and the battery it has to be in a metal battery box with the box being a certain thickness (l think 1/16th"). The switch has to be clearly visible and accessable with it cleary showing which was is off. If it's a push/pull type, "OFF" has to be PUSH. Here the legal and correct way to wire it. -Mark
also just for you guys that still drive em on the street flaming river has a kit that uses a removable rod for the cutoff and if you just get an extra taillight housing you can drill the hole in that housing to have it go through there with the switch and all so that you dont have to drill the tail panel or worry about not having a tail light for the street
This one.... LOL LOL
I leave it in.....
Kyle
Originally Posted by JL ws-6
Kyle is that technicially legal without the battery sitting inside a box? or is it being behind the plastic (which i assume you usually have in place) good enough so they don't bother you?
-Mark
Originally Posted by Bitemark46
If there is no divider between the driver and the battery then it has to be in a metal sealed box. If there is a divider between the driver and battery (has to be a certain thickness of metal) then it can be in a open container.
-Mark
-Mark
Yep yep... what he said......
We bought the BMR Battery Tray... a BIG POS in my mind... what is it good for...???. it isnt legal and you cant fit any metal box in it.....
