90/90?
90/90?
Does the fast 90 intake use the same hardware as the ls6? What is the best TB for this set up? What mass air sensor should I use? Where can I get these items for a good price?
Thanks Aaron
Thanks Aaron
you will need a 90mm tb to match the intake opeaning on the manifold. the bolt pattern is different i believe also than the ls6. and any of the sponsors can help you out with a purchase
Thanks Aaron
Thanks Aaron
Call TSP they have they best price for the 90MM combo.
We just put down 460rwhp through and LS6 intake, MS3 (237/242 .603 .609 113LSA), PRC stage 2.5 5.3L heads (1199 assembled )
We are swapping the FAST 90/90 onto the car today, I will post up the GAINS and disprove this immediately.
We had a fast 90/90 pick up over 30 on a 98 H/C car last week coming from the LS1 manifold.
Thank You.
Still waiting after the results from ZACH @ TEXAS-SPEED about the improvement between the LS6 and the 90/90 combo
Christian
Originally Posted by miami993c297
FROM ZACH :
Thank You.
Christian
Thank You.
Christian
Originally Posted by 1 BLOWN V8
I would like to see this also. Also what motor are they doing it on. A stroker or a LS1?
https://ls1tech.com/forums/generation-iii-internal-engine/606697-results-etp-heads.html
asa Zach will be in better shape the results will be there for sure, with the 5.3l head I guess it's a 347Ci.
Christian
