ATI ProCharger Supercharger Specifications, including F1A
what kind of characteristic differences do the d1sc and f1 or f1a have in terms of boost response on a 346/347 motor. can you run a f1/f1a on stock block, like a d1sc on low boost and then turn it up later when the fuel and motor can handle it?
If you had a cam with a lot of overlap and some great flowing heads, you might get the boost down to where these larger head units will work. I don't off hand know of anyone who has tried it though. Bob
Originally Posted by Exotic Performance Plus
The F1/F1A blower have a 5.40/1 step up ratio instead of the 4.10/1 ratio found in the smaller blowers. With the largest 8 rib head unit pulley ATI normally has is a 4.50 ( I have a 4.75 and a 5.0 that came from ATI) there is no way you could normally run the boost at a level that the stock bottom end could handle.
Does the F1 reqire a different intake hat, bracket, etc. How exactly would it be setup? I liked that elbow that you guys had on your site instead of the ATI hat. Is that available?
Originally Posted by big reg
Hey Bob, the F1-A is a direct replacement for the D1SC in terms of fit correct? I think I remember you saying it was a $450 upgrade as well?
Originally Posted by BLASTER
i was actually thinking about going this route. Assumed I would be short shifting it as well.
We can indeed make you the inlet hat combination that we made for the white T/A. Thanks for inquiring. Bob
540, ati, boost, d1sc, f1, f1a, head, information, low, pics, procharger, range, rpm, specifications, specs, supercharger, unit
