Livernois Motorsports New Stage III Race Head
Old 11-21-2006, 03:38 PM
LS1TECH Sponsor
Chad@LivernoisMotors's Avatar
Default Livernois Motorsports New Stage III Race Head
We have been working very hard on redesigning and improving our LS6 CNC Stage III Race head.
The Stage III Race head is fully assembled and comes with Manley dual Valve Springs,Manley Seats, Titanium Valve Spring Retainers, SI 2.100 valves.
----- Intake --- Exhaust
0.1 --- 78.5 --- 58.7
0.2 --- 160.4 --- 120.8
0.3 ---228.2 --- 168.8
0.4 --- 282.5 --- 195.2
0.45 --- 309.4 --- 205.8
0.5 ---323.4 --- 215.5
0.55 --- 328.8 --- 222.1
0.6 --- 332.5 --- 228.4
0.65 --- 332.5 --- 230.5
Pricing starts at $2,199.99
Any question/comments/ orders please PM or email me at cmaley@livernoismotorsports.com
Chad @ Livernois Motorsports
Old 11-21-2006, 04:09 PM
forgedbluess's Avatar
Those #s look good man ill let you know when im ready for them.
Old 11-21-2006, 04:10 PM
bobby1's Avatar
Default stage 3 head
will this head work with a 346 motor with a big cam and 456 gears
Old 11-21-2006, 04:22 PM
LS1TECH Sponsor
Yes.
Forgedbluess- Give me a call when you decide.
Thanks,
Old 11-21-2006, 04:45 PM
Beast96Z's Avatar
It may work, but it wouldn't be optimal. The 2.100" valve will be severly shrouded by the cylinder wall. There was a thread going around a while back that showed anything bigger than a 2.04" valve on a stock bore was getting pointless.
bobby1's Avatar
thanks will get with you on that soon after christmas
Old 11-21-2006, 04:47 PM
bobby1's Avatar
just to make sure these heads on the intake side with 600th life make 332.50 cfm
Old 11-21-2006, 05:00 PM
bobby1's Avatar
i have the lg 5 cam and i want to fully take adavantage of this cam
Old 11-21-2006, 05:02 PM
bobby1's Avatar
i've read about ttperformance and there ported afr 225 heads making 505 rear wheel on a 9 inch rear end
Old 11-21-2006, 05:32 PM
SLP4CamaroSS's Avatar
do you guys plan on making the stage 1 or 2 any better???? good job on the stage 3
Old 11-21-2006, 05:33 PM
Z06 Steve's Avatar
what about on a stock LS2 4" bore 07 Vette motor?
Old 11-21-2006, 05:56 PM
GuitsBoy's Avatar
Theyll be much better suited in there.
Chad, What bore were these flowed on?
Old 11-21-2006, 06:46 PM
Beast96Z's Avatar
Try putting all your questions/statements in one post instead of wasting 4 posts. Not to mention this statement dosen't really have anything to do with the thread.
Old 11-21-2006, 08:24 PM
1999 SS's Avatar
can you PM me a price to install these heads and tuning? i live in Clinton twp so im only 1\2 hour away from you guys.
im running a Futral f14 cam with ALL the bolt ons so would these heads be overkill? should i be looking at the stage 2's instead? the car is a weakend toy only not a DD.
Old 11-21-2006, 10:05 PM
LS1TECH Sponsor
4.030" Bore.
Actually we are showing very good results with the 2.100 valves and I'm sure the dyno results will prove it. I plan on putting a set of these on my personal car in spring if money permits, so we will see what they can do through a stalled auto.
I'm currently at home but I will send you a detailed PM tommarow for a quote. The Stage 3 Race heads would work perfect with that setup, they arent as "overkill" as alot of people might think. And they will make some GOOD numbers.
Old 11-21-2006, 10:50 PM
Beast96Z's Avatar
Originally Posted by Chad@LivernoisMotors
4.030" Bore.
Hope it works out, but it seems that by the time you shrink the bore back down to 3.9" that flow would be back at the level of your normal Stage 3 head. Then it seems you would have lost some port velocity and disrupted the distribution of air into the cylinder. With a valve that is more than half the size of your bore, I can't see how it isn't shrouded. Once again, I really hope it works, and kudo's to you guys for putting another option out there, but it seems to me like the normal stage 3 head may be the better bet for a max effort 3.9" bore car. Either way, you guys sell a head, but I wouldn't want some daily driver guys to think this was their best bet.
Old 11-22-2006, 06:08 AM
No Juice's Avatar
Is this the same port that was used on the Stg III head in the GMHTP magazine but with a 2.04 valve?
Your website shows that we can get the Stg III head with a 2.02 valve as well ?
Old 11-22-2006, 08:57 AM
LS1TECH Sponsor
Yes, that was our new Stage 3 Race Head with 2.100 valves. Since then we have slightly improved it to get a little more compression.
You can get the Stage 3 head in a 2.02 valve. However the new Stage 3 Race is only 2.100 Valves.
Stage 3 Heads use a 220cc runner
Stage 3 Race Heads use a 240c Runner
Thanks,
Old 11-22-2006, 10:16 AM
bobby1's Avatar
i'm new at this but the reason i brought up ttperformance is that they port out the afr 225 heads to flow over 320 cfm. i'm just looking to find a head that will work best with my cam and the reason i'm asking i'm in the head market. My car is a daily driver but the cam is about the same size as the texas giant 248/254 611/613 in a 346. i just want a head that will work with my combo now and if it works best when i do a 408 so be it.
