Biggest cam for a 3200 stall?
Old 11-21-2006, 04:10 PM
snketr's Avatar
Default Biggest cam for a 3200 stall?
This is my DD and it'll be the first internal mod. Only other mods are FLP Lt's ORY, and Hooker cat back. I'm getting the stall for free and plan on sending it to Precision to get checked out before I install it. So, what's the biggest meanest sounding I can go? I can live with alot, my old vette would die 1 out of 10 stop lights.
I was thinking the TRak cam or similar to the one PatrickG did on a 110.
Old 11-21-2006, 04:14 PM
GeArBaNgEr56's Avatar
Good question, I'm thinking of getting the TSP torquer 2 with a 112 lsa. I've heard it in person and I was sold.
Old 11-21-2006, 06:07 PM
TXZ28LS1's Avatar
i would like to see how this post turns out also. im looking at a 3200 stall too!
Old 11-21-2006, 07:06 PM
Cld069's Avatar
Im all ears...
Old 11-21-2006, 07:22 PM
1WICKDZ's Avatar
torquer 2 would be just about right i think
Old 11-22-2006, 08:18 AM
snketr's Avatar
Only one opinion???
Old 11-22-2006, 08:19 AM
GregWS6&z28's Avatar
torquer 2 is nice
Old 11-22-2006, 09:03 AM
hammertime's Avatar
Patrick G cam would work well with the lower stall speed. More torque at lower speeds will help flash the converter higher when needed (within reason, it's obviously not going to work like a 4000 stall).
If you haven't yet, read his comparisons between the TRak cam and the 224/224 110+0 cam. Lots more bottom end, still pulls well to 7000.
Old 11-22-2006, 09:08 AM
hammertime's Avatar
Also, since I don't see heads in your setup, you may want to get an adjustable timing set and install it 2 degrees advanced, or even 4 degrees as long as clearance allows. Earlier intake valve closing would net you a higher DCR and better low-end response than installing straight up.
Old 11-22-2006, 09:51 AM
jlashley2001ss's Avatar
with that stall a 224/228 110+2 or maybe 226/230 110+2 would be good. either way it will pull like a raped ape!
Old 11-22-2006, 03:53 PM
Wheeler99WS6's Avatar
TSP228R with 112lsa
Quick Reply: Biggest cam for a 3200 stall?
