Milling heads and getting thinner head gaskets
Old 11-27-2006, 04:43 PM
11Second Club
Gauge's Avatar
Default Milling heads and getting thinner head gaskets
Hey all,
I'm getting my heads milled and getting some thinner Cometic head gaskets. What's the limitation where I'm going to start running into issues with intake manifold fitment? I'm going to .040" head gaskets from the .054" stockers. I'm assuming that the thinner the head gasket the less I can mill. If that's true, then what's the maximum amount I can take off between the two?
Thanks in advance for any help!
Old 11-27-2006, 04:52 PM
BriancWS6's Avatar
I have mine milled .024 and run the .040 Cometic gaskets. Everything fit just fine. How much of a mill do you have in mind?
Old 11-27-2006, 04:53 PM
66deuce's Avatar
my heads were milled about .040.and i went with a cometic .045 gasket.no fitment issues.but i'm sure it will vary from motor to motor....
Old 11-27-2006, 06:05 PM
LS1Tech Sponsor
Slowhawk's Avatar
We run into problems with .055 milled on stock gaskets.The intake doesn't sit right.
Old 11-27-2006, 06:37 PM
11Second Club
Gauge's Avatar
I was hoping to mill about .040" off the heads and run the .040" gasket (thus taking off another .014". Based on what Slowhawk is saying, that's pushing it. Perhaps taking off .030" would be safe with the .040" gaskets? (Total of .044" taken off)
Old 11-27-2006, 06:54 PM
pdd
pdd's Avatar
thats what im doing
Old 11-27-2006, 07:53 PM
11Second Club
Gauge's Avatar
Originally Posted by pdd
thats what im doing
Have you actually done it yet? Any success?
Old 12-03-2006, 06:13 PM
11Second Club
Gauge's Avatar
Can anyone tell me what I can safely mill off my heads with .040" gaskets? Is .030" off the heads and a .040" gasket (thus .014" off the stock gasket) acceptable? I imagine that would be the same as milling .044" off the head with stock gaskets.
Old 12-03-2006, 06:40 PM
pdd
pdd's Avatar
im in the process but car is off road till spring
Old 12-03-2006, 10:01 PM
mullenh's Avatar
Post
there is a maximum and someone will answer soon i am sure. This question has been asked b4. and it seems like .03 was the max witha stock gasket but i can't remember.
Old 12-04-2006, 02:51 PM
slick1851's Avatar
Bump because id like to know also
Old 12-04-2006, 03:46 PM
11Second Club
Gauge's Avatar
I called TSP today and asked them. Zack told me that I could safely mill .040" and use the .040" gasket. I (to clarify) asked him if he was sure it was okay to take a total of .054" off the bottom of the heads. He said yes.
Anyone want to comment on this? I'm doubtful, and I need to let my machine shop guy know how much to mill pretty soon.
Old 12-04-2006, 04:37 PM
Studytime's Avatar
Even if it doesn't line up, take a cartride roll to the intake manifold and a carbide bit to the runners and make them line up.
Ben T.
Old 12-04-2006, 04:43 PM
Irocss85's Avatar
Im also goin 030" mill and .042 gaskets. Im goin to use the mr gasket gaskets. ET performance told me they have taken .030 and .040 off before, typically they do .030 though.
11Second Club
Gauge's Avatar
Ben T.
I'm not sure what exactly you mean. I was wondering if the manifold could be modified to deal with fitment issues, and I'm definitely willing to do a little modification.
When you have fitment problems, how do they usually manifest themselves? Bolts won't go in the bolt holes? Manifold won't sit down all the way? Intake ports on the heads won't line up with the manifold? All of the above?
What exactly would you do with the "cartride roll" and the carbide bit to make it fit properly?
I'm sure I could figure all this out when the time comes and have it work out for me, but I'd like to be prepared and know what to expect.
Old 12-04-2006, 04:46 PM
Irocss85's Avatar
he means port match the heads to the intake.
Old 12-04-2006, 04:51 PM
tbick's Avatar
whats the largest cam one could run without flycutting the pistons with the heads milled .040
Old 12-04-2006, 04:55 PM
Studytime's Avatar
You might have to "shrink" the alignment pins a little to get it to line up, but the intake bolts should go in. If not, don't force it. If the ports don't line up well, they could be adjusted by port matching the two.
tbick, there will be no black-and-white answer for that question.
Ben T.
Old 12-04-2006, 07:10 PM
11Second Club
Gauge's Avatar
Ben T.
Is port matching something one can do for himself? Or does this require special equipment? Can you give me a brief description of how it's done?
Old 12-04-2006, 08:48 PM
GuitsBoy's Avatar
Ive got .040 off my heads with a .054 gasket. Rule of thumb is that at around .050 you run into intake gasket fitment issues, but then again simply replacing the smooshed and cooked rubber will likely fix that easily enough. Once you get past .050 you may start to hurt head flow according to some big name porters. I wouldnt think it would plummet, but something to keep in mind.
For portmatching, I made a rubbing of the head ports and marked where the edge of the head sat. Then i placed the intake on and marked where that sat on the other side of the paper. Then pull the intake and you can line up the paper to where it sat on the intake and kind of feel if the ports are aligned with the rubbing marks on the paper. sorry if thats confusing, but its actually quite easy. I dont think youll be far off enough to make a big difference.
