Some 4L80E Questions
Old 11-27-2006, 07:39 PM
calongo_SS's Avatar
Default Some 4L80E Questions
Is there any specific year I should look for, or just any 4L80E? A buddy of mine has one that needs a rebuild he'll let go for cheap, but he doesn't know what it came out of.
Does the bell housing bolt right up, or is there a conversion peice?
Does anyone make a RMVB w/ a brake for the 4L80E?
What shifter works w/ this trans?
Old 11-28-2006, 12:25 AM
calongo_SS's Avatar
OK so I did some reading, it looks like Rossler makes a t-brake, but you keep the auto VB whic is fine with me.
So the stock shifter will be ok?
What about the bell housing?
Any specific year/model trans I should be looking at?
Old 11-28-2006, 07:21 AM
FLT
FLT's Avatar
I would look for a 99 and later 4l80e. When you get a TC have it built with an LS1 front cover. If you have any questions or would like to order one, feel free to give us a call.
Z'mnypit's Avatar
You will need a 97+.. The older ones will work but will need some modifications. They are also not as strong. The bellhousing will bolt up, youre going to need a converter made to fit the 4l80e but yet bolt to the LS1 flywheel. The PCM has to be modified, you'll need a crossmember, a wiring harness, TH400 slip yoke and the stock shifter will work. The stock drive shaft will also be fine. I think thats about all I can think of right now.
Old 11-30-2006, 12:57 PM
MiaSSmaro98's Avatar
on what did these trannys come on?
Old 11-30-2006, 01:02 PM
calongo_SS's Avatar
I wanna say it was/is 3/4 ton trucks, but I'm not sure exactly other than some full size trucks.
Old 11-30-2006, 08:53 PM
DEEZ98Z's Avatar
The trannies came in 3/4 ton trucks and vans.
Old 12-02-2006, 11:53 AM
calongo_SS's Avatar
Is there any special mods that the builder will need to know about when putting this trans together to make it work in a f-body? (internal, input/output shafts, etc..???)
Old 12-02-2006, 02:21 PM
DEEZ98Z's Avatar
Nope there isn't anything special that you have to tell him.
Old 12-02-2006, 05:12 PM
calongo_SS's Avatar
cool, thanks.
Is there anyway to tell by looking at the trans what year vehicle it came out of? My buddy thinks it came out of a 99, but I'll be pretty upset if it's a 95 or something and I dump a bunch of $$ into it.
Old 12-03-2006, 11:32 PM
calongo_SS's Avatar
cool, thanks.
Anybody?
Old 12-04-2006, 07:17 AM
Z'mnypit's Avatar
cool, thanks.
PM cablebandit. He told me once how to determine the year btw the modle # or something but I cant remember the exact way without looking at the trans.
Old 12-04-2006, 08:36 PM
calongo_SS's Avatar
I got no response from him, anyone else know?
The core I have came out of a 1 ton truck, but it's the same trans whether it came from a 1 ton or a 3/4 ton right?
Old 12-05-2006, 06:54 AM
Z'mnypit's Avatar
The trans itself will have the model on it. Mine has 4l80e right on the side of the casing. Only other thing you will need to know is the year model it came out of. Someone your suppose to be able to tell that by the part #.
Did he not know or did he just not reply?
Old 12-05-2006, 11:39 AM
calongo_SS's Avatar
he didn't reply. I really hope this trans my buddy has is the right year, it sure would save me some cash.
Old 12-06-2006, 07:22 AM
Z'mnypit's Avatar
Whats the part GM# off of it from the side? BTW- it will still work if its not a 97+ but they supposedly arent as strong prior to 97+
Old 12-06-2006, 07:43 AM
calongo_SS's Avatar
I thought the electronics were different between pre 95, 97 & 98, then again 99+. The trans is at my buddies place, I have him look for a # on it.
Old 12-06-2006, 08:15 AM
FLT
FLT's Avatar
Here is a picture of what the 99+ bell looks like. If you get an earlier unit it will not have the bolt hole at the 12 o'clock position. This is a ls1 bell.
Old 12-06-2006, 02:16 PM
calongo_SS's Avatar
cool, thanks Vince.
Old 12-21-2006, 12:22 PM
calongo_SS's Avatar
I just thought of a nother question, will Lock-up remain automatic like in the 60, or will I have to use a switch?
