what internals for a forged 346 on boost
Old 11-28-2006, 03:14 PM
JASON11WS6's Avatar
Default what internals for a forged 346 on boost
I am going to be running a D1sc with around 10#s at first and probably upping that to around 15# later on. I would be runing the stock block and crank with LQ9 truck heads from Patriot. I am gunning for a compression ratio of around 9.5:1 so I figure I am looking for piston that's about the same dish as stock. Just looking for the right parts for as cheap as possible that aren't going to break or need to be replaced every thousand miles. I was thinking crower rods and diamond pistons but I'd like to get your ideas on the subject.
Old 11-28-2006, 05:24 PM
chriswtx's Avatar
He's what I am building for my boosted motor..This piston with the LQ9 heads will be 9:1 compression..
Motor details
346ci, Eagle LS1 6.125" rods, Diamond -8.6 dish pistons, stock crank, new LS6 block, ARP head bolts, custom ground Comp Cam 226/232 116LSA, Texas speed CNC LS6 stage 2.5 heads 64cc chambers 2.04intake 1.575 exhaust valves, Will put me right at 9.5:1 compression.
Old 11-28-2006, 05:39 PM
KHShapiro's Avatar
the only thing special really is a Boost/NOS piston and most people use Diamond Pistons.
And make sure the rods you use are ls1 specific.
What you really need to think about is the power lvl you want to acheive, Stock cranks and Rods 99+ with upgraded rod bolts work great.
You can check out my link and see what all i have, its a bit extreeme but hey i am shooting for al lot of power
Old 11-28-2006, 06:35 PM
JASON11WS6's Avatar
Would they be worth using in a 700 rwhp motor? I have heard of people staying stock with upgraded rod bolts before but I'm not sure what kind of power levels they were hitting.
Old 11-28-2006, 06:40 PM
chriswtx's Avatar
Guys at ECS have seen stock rods bend at 640rwhp..$400 for good rods is cheap insurance when building a forged motor...
Old 11-28-2006, 08:11 PM
JASON11WS6's Avatar
I agree, that sounds like to much power for the stock rods. Does anyone know how crower rods (LS1 rods) are? SDPC sells em for like 485 or something like that which is pretty cheap. I was thinking about them since crower is a pretty good product but I haven't heard about to many LS1 builds.
Old 11-28-2006, 08:26 PM
SSilverSSurfer's Avatar
check out hte compstar rods, theyre pretty cheap from what ive seen and theyre good
Old 11-28-2006, 08:30 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Diamond -4cc is what I use w/ 6.0l stock crank and Eagle 6.200 rods.
Quick Reply: what internals for a forged 346 on boost
