x pipe or cat back
x pipe or cat back
i am getting the pacesetter LT but i also had a vision of and x pipe comming out the side skirts b4 the rear wheels any proformance problems or just problems in general let me know
Not sure what you mean by x pipe coming out the side, I think you mean a true dual system that exits out the side. its been done before, ground clearance will be next to nothing.
Originally Posted by mighty mike
the side exit was only an idea (because less pipe means less money) but in reality i got the idea off the vet
just look at tsps rumbler x and scratch the idea of side exits and if youre on a budget scratch the rear exit idea too.. which if your a camaro doesnt matter looks wise much anyway
The only way side exit *might* work with adequate clearance is if you use oval piping and have elongated wide tips but I have not seen one done professionally before for the fbody application. Surprising.
Ride in a car with dual before you get them. I had then and got rid of them because the interior noise is horrible. They sounded sweet at WOT, but sucked besides that.
i have made the decision of pacesetter lt, x pipe, and dumped he said around 700 for cats and muffler and stainless pipes and all the bending and install.
