GMPP manifold and oem mounting style fuel rails?
Old 11-28-2006, 10:14 PM
SVC707's Avatar
Default GMPP manifold and oem mounting style fuel rails?
ive got this setup which was machined by one of the sponsors. but it is leaking fuel from the injector bosses and the fittings into and out the rails. ive tried teflon tape and paste. te injectors are just too loose on the injectors but in my speedinc rails they ARE VERY snug. i tried to adjust the two mounts bars that are used to set it all in place. but it still leaks.
who has made the speedinc or other rails fit in the threaded locations located in the same location as the oem rails do
Steve
im posting this here and other sections because not sure who would see it where. and im at the frustration level.. sorry
Old 11-29-2006, 12:34 AM
red90cobra's Avatar
i believe you can fix this by using a different injector o-ring i'm not sure the size difference though. Are you sure the injector o rings aren't riped or torn?
Old 11-29-2006, 12:38 AM
black98ws6ta's Avatar
My gmpp was also drilled so the injectors dont seal good, but it sealed on the fuel rail side.
Old 11-29-2006, 07:57 AM
smokinHawk's Avatar
can you get thicker o-rings for the injectors?
Old 11-29-2006, 08:22 AM
SVC707's Avatar
o rings are not torn. they slide right in with no drag. but with the speedinc rails i HAVE to use oil to put them in. i will see if i can get thcker o rings but i would prefer to use the other rails. but i will try and use these then im taking it off AGAIN
Old 11-29-2006, 12:34 PM
Nasty N8's Avatar
You could drill the other rails to match the standoffs.
Nate
Old 11-29-2006, 12:53 PM
MrDude_1's Avatar
Nate
i would do what nate is suggesting.. just be sure to use a drillpress and measure, measure, measure.
Old 11-29-2006, 12:56 PM
SVC707's Avatar
im going to take it all off and probably just take it to a machine shop. im not trying to burn down my whole car with this leak. ill let them figure it out. ill see if they can make stands for the speedinc rails and cut off the one that extend sideways. and/or just machine it like nate says.
Old 11-29-2006, 01:03 PM
red90cobra's Avatar
i thought so. maybe I'm worng
Old 11-30-2006, 09:08 PM
SVC707's Avatar
all done and no more leaks
will finish up the rearend and get this textralia exoskel installed and off to synergy finally get some numbers on this combo
