New Times
New Times
Mods:
pacesetter long tubes
hooker cat back
moroso cai
nitto dr's
Best run was a 13.7 @ 102, with a 2.3 60ft
Really couldnt get the tires hot, everytime i tried a burnout the car would just slide sideways? Temp was real cold outside i think in the high 40's, abnormal for AZ. Track prep wasnt the best, nobody was really hooking too well.
I was happy with my times i was atleast hoping for a 13.9
Cam will be coming soon, pretty sure im going with a cc305 220/230 114.
Do people usually do oil pumps with the swap? I know my pressure runs real low. About 18psi at idle, 35 at cruise, and not sure at WOT.
hooker cat back
moroso cai
nitto dr's
If your thinking about getting a CC305 cam you should by my used one. $75 for the CC305 on a 114lca, and CC springs and retaners that will support the extra lift. The cam has a few 1000mi on it, and my car went 11.70 at 115 cam only with this cam.
Originally Posted by Speed Density
255/60/15 Mickey Thompson Drag Radials.
Best out, even with my new setup im sticking to a DOT class and running a larger MT DR.
Tony.
Tony.
Originally Posted by ReD95LT1
Mods:
hooker cat back
moroso cai
nitto dr's
hooker cat back
moroso cai
nitto dr's
You should check out AZFBA.com, we have our own message board with a lot of knowledgeable people from a various backgrounds and a nice amount of sponsors.
I would stay away from a 305, that things is small. You should probably do a hot cam kit if you want to do it for 500$. There are many more cams out there that are just as streetable but will make more power.
no i ran at speedworld on friday night. my friends were there on saturday and said they track was the same as friday. so im not too worried.
The 305 makes more power, from what i have been told, than the hotcam. And i cant pass up a deal on the cam,springs,retainers, and locks for $75 bucks!
Did you run at speedworld this weekend at all?
no I am currently finishing up a few things on my new cam only setup, so negative but my friends were there. that is a good deal, make sure you do rockers too if the price is right! two people here in phx ran 12.4 @ 111 with that cam and some crazy driving, so lets hope for the best!
yeah, definitely going with 1.6 nsa rockers, pushrods, guideplates, 7/16 stud, all gaskets, not sure which timing chain, and msd cap and rotor.
ill be glad to be in mid 12's. its my daily driver so that is fine with me
m6....
I have nitto drag radials, but i just couldnt seem to get a good enough burn out going to heat the tires well enough. I have NEVER hit a 60ft better than 2.2
Nobody could really hook that night, i was spinning all through 1st and somewhat through 2nd.
I was with my friend who has bolt ons and recently installed cam in his 98 ta ls1. His best was a 13.2 @ 111 with a 2.3 60ft
Cant wait to see what i run with the cam. May go once more before the cam swap to see if i can improve.
