what makes a bigger tb better
what factors make a 90mm tb better than a 78mm better i just want to konw befor i buy cuz i am looking at the fast intake and the tb but i just want to konw why 90mm ( thats what i am gonna get cuz everyone told that one but i wanna konw why )
im biting my lip not to flame this........so here i go with the nice answer....a larger tb will allow more air into the top end of the motor allowing more power....but your going about this all wrong....1. you dont have the right parts to even consider going with a 90mm...no manifold, improper exhaust....so this tb you want would be just a big waste of money....2. there are a miriad of things you NEED to get and SHOULD get before even thinking about that tb....short lesson
if your going to add intake parts, you need to add a exhaust part in the process to get the most out of your parts...and vice versa.....for example....port your 78mm, get a ls6 intake,====get some headers and a catback system....youll see major gains out of those 4 parts TOGETHER
remember there arent stupid questions.....just stupid people who never raise there hands
well i am putting a lot into it over the winter hedders intake exhaust ( straight ) but this is what a few ppl here told me to do so i am listining but i havent bought anything yet i am just doing the reshearch right now
but does that give me more reason to get the 90 or no
if your going to get a 90mm tb you need to do it right and get a 90mm manifold to....thus "90/90" setup.....but that will run you close to a grand...and until you have some internal work done...its not worth it in my opinion....your stock cam isnt going to open the valves enough to use all of the induction that setup will give you.....just go with a ported tb and a ls6 manifold like i said....that will cost you around half the price
not too hard if you have the tools and are mechanically inclined.
https://ls1tech.com/forums/generation-iii-external-engine/442896-tb-porting-tips.html
there are people who will do it for you too for a small fee. ask in your regional section.
Originally Posted by mighty mike
so what would it take for me to put a 90mm on for a tb and an intake? i was planning on lt headers and stright pipes. do i need more???
Let me give you the typical engine lecture. A motor is a big vacuum: yadda, yadda, yadda. The better the motor flows, the better the motor performs. If you got a nice heads/cam set up, it would definitely benefit you. The only problem is that the performance would be greatly crippled without a proper intake and exhaust set up. As it stands now with your stock LS1, the only thing that is really crippling the stock motor from performing to its limits is your exhaust.
Everything must match. There is no need to spend $1000 getting a 90/90 when your motor currently flows just fine. Wait until that heads/cam goes in, then it will be begging for more air. That will be your cue to add the 90/90.
