true dual muffer options?
Old 12-04-2006, 07:11 PM
88zukon36s's Avatar
Default true dual muffer options?
I am planning a true dual set up out the back with mufflers behind the axle. What are my options for the mufflers that fit behind the axle. Any advice and help will be great. I have searched and found some mufflers but just not sure on how to set it up. Thanks
Old 12-04-2006, 08:22 PM
staringback05's Avatar
spiral, glasspack, flowmaster,slp bullets....and another type i cant remember the name of but are only about 6 inchs long and round as a pancake....heard good things about them.....
Old 12-04-2006, 08:25 PM
SuperSlow02's Avatar
magnaflow bullets sound the best
Old 12-04-2006, 09:01 PM
zlover129's Avatar
sweet thunders
Old 12-04-2006, 10:30 PM
SUTTERERMAN85's Avatar
dynomax bullets FTW
Old 12-05-2006, 12:24 AM
HotWhipT/A's Avatar
Flowmaster 1 chambers (10 series). They fit...I have it done on my car no problem! Find the demensions on them, Its like 8 x 6 x 3.
Old 12-05-2006, 04:30 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Flow Pro Twisters is what I run on mine.
Old 12-05-2006, 05:20 AM
300bhp/ton's Avatar
Pretty much any muffler of any brand can be made to fit. It all depends what you want, volume, tone, cost, appearance.
Are you running X or H mid pipe and are you running CATS?
Personally I like loud in your face muscle car sounding exhausts. So I'd look at chambered mufflers. Powersticks are a good bet, Stainless Works or if you are running cats even SLP LM1 resonators.
There's no right or wrong only individual opinion.
Old 12-05-2006, 12:27 PM
88zukon36s's Avatar
Hey Hot Whip thanks for the reply. Do you have any pics of your set up? Or any other set up with mufflers behind the axle.
Old 12-05-2006, 12:53 PM
lsx24's Avatar
It depends what you're goals are for the system. If you want to actually muffle the exhaust you need a real full size muffler, or something similar. For a real muffler than fits in tight spots look into ATR/Pitbul mufflers. Speed Inc used to use them in their true duals systems that had the mufflers in the same place. Or look for something similar.
Otoh if you want it loud and don't mind it loud, then go with a spiral straight through muffler. If you want it REALLY loud just go with bullets, but imo duals with only bullets are obnoxiously loud.
As an alternative have you thought about a single dual-in dual-out muffler behind the axle? Check out my other thread on that, it is more refined than most true duals.
Old 12-05-2006, 02:00 PM
jlashley2001ss's Avatar
would magnaflow bullets and cats w/ H-pipe be really loud? im thinkin of doing this over the axle w/ 2.5" pipes
Old 12-05-2006, 03:46 PM
JEB Garner's Avatar
88zukon36s, Use the round MagnaFlow mufflers (The Noise Cancelling, straight Through Design) Place one on each side of the rear tub.
Old 12-05-2006, 08:36 PM
HotWhipT/A's Avatar
No pics. I haven't had time and its not totally finished. I do have a video of what it looked like, the rear is the same...but I redid from the headers to the axle because the damned shop couldn't do it right.
The passenger one is slanted to fit. Doesn't have any effect on sound FYI.
Old 12-06-2006, 10:42 AM
BitViper's Avatar
That sir is a nasty Cam.....what kind of mufflers are you running?
The worse sounding mufflers to me....are ones that make a sleek car sound like a truck....
I love the sound of the stock Dual-Dual....very refined until you punch them
Old 12-06-2006, 05:35 PM
how well do those flowmaster one chambers flow?....
Old 12-09-2006, 08:41 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Hotwhip, your exhaust must be 10 times more restrictive than mine. I don't see how you can get that close to the tailpipe without having it whip your *** as well as the camera.
Old 12-09-2006, 02:58 PM
HotWhipT/A's Avatar
They flow just fine!!!! I don't actually have an (aftermarket) cam...I just took off a vacuum hose. I had other vids, but not showing anything. The exhaust had quite a bit of velocity when I didn't have the H pipe on it. I don't know what to say, I was a bit suprized about how well the camara recorded. I just have a badass camara, hu?
