Fog Light Change
Fog Light Change
Hi I have a 1998 Z28 and I am wondering will I be able to replace my right side fog light by going under the hood? or do I have to go under the car? Also I put my car away for winter and it has a full gas tank. I start it up about every 2 weeks. Will it help to put fuel stabilizer into a full tank? Thanks in advance
on my ta..i did it last nite actually i had to go under the car.....there is no way i could have done it on top....how do you camaro guys do it...and to actually remove the fog light from the facisa, i had to , even the service manual says to....remove the fog light housing from the mounting bracket..if there is an easy way..... please tell me
yea u can replace the blub without removing the housing..anain i did that from under the car..in my case the lens was cracked and i got a replacement...but again in my case a trans am....from under the car the removed the housing bolts but due to the fasia i couldnt get it out...service manual said to remove the fog housing from the bracket..a biatch....but it worked...if any of u guys know of a slicker way to remove it let me know...ps it also knocked the light out of adjustment..got to do that when the spring comes
