little milling help please.
im going to be buying the PRC stage2.5 5.3L heads and i want the final compression to be about 11.5:1 i think ive determined that it will take about .030 milling to reach 11.5:1. could someone confirm this for me? also im getting the TSP228R 228/228 .588/.588. now will this run into clearance issues or is the lift small enough that i wont have any issues? i think it will be fine but id like some conformation for a some peac of mind. thanks.
Originally Posted by PREDATOR-Z
Do you want to run premium? then 61cc would be Ok. That is .015 mill.
But first measure chamber with a burette and mill from there.
oh ok. thanks alot. ill just ask my mechanic what he thinks and go from there... you wouldnt happen to know the max lift these heads will take without having to flycut? and with the .015 milling does that just take .015 away from the max lift you can have?
