Injectors?
Injectors?
I have a forged piston, fully balanced 355,w hot cam and i want to know what is the stock injectors capable of i think i need more fuel? If so what size?
stock might work if not 30lbs will get the job done. do some logging wtih datamaster if you have the ability and look at the duty cycle of the injectors. anything over 85-90% calls for bigger injectors.
I have the same exact setup and am putting down numbers in sig. Have a high rpm miss and turns out my injectors can't keep up with my setup so I'm goin with Delphi/Racetronix 37#'s
Internet Mechanic
Ok so if i go with 30lb injectors i have a pcmforless tune will i have to get it tuned again or what will i need?
By the way Thanx for the info!
There is basically your PE (power enrichment table, your basic fuel map) then afterward there is a correction that you can do by a percentage. PCMforless will ball park it and make a across the board correction to run it safe.
